This morning I’ve got a couple of “open”/“close” messages, 5-6 times till now. Immediately after the open message the close status was present. Between the two cycles were sometimes 10 and sometimes 20mins. But the door was always closed and locked.
Hi, I have re-calibrate the sensor with a little bit bigger gap at the “keep the door open with a little gap” step. Since yesterday no new open/close flooding.
Thanks for the hint!
I did a reset and recalibration according to your advice …
The gap is now about 3 cm instead of 1 cm.
A developer from NUKI should comment, which effect this has to the problem of random continuous open/close messages !!!
I installed both smart lock and door sensor latest updates (1.1.2 for sensor and 3.4.5 for smart lock). I’m having random bit consistent “door sensor removed” warnings which I 'eed to fix by unclipping the sensor waiting a few seconds and clipping it back on the frame. At that point it immediately detects a door closed status and keep working for a few hour or sometimes a day or two.
After about two months of usage, the battery of my door sensor died. Replaced the battery and upgraded the door sensor firmware to 1.1.2 the sensor works again, but the battery is directly marked as “critical”.
I am using a Smart Lock 3.0 Pro and the Beta firmware 3.5.0 including the mqtt api. No Bridge.
A second brand new battery shows the same result. Door sensor battery state critical.
Edit:
Door sensor state critical due to wrong batteries ER14250-3V instead of ER14250-3,6V.
As if it was extracted/removed (and it wasn’t). Same issue I’ve been facing since I bought it. Beta updates improved but def didn’t fix the issue.
An update on this, I haven’t received the warning again since I made the little pin longer, as was reported in the above link. I stick some little piece of thick tape so that the pin is pushed deeper in the housing when mounted on the wall. It seems the pin is a little on the short side by default ?
