Here my wired intercom
Sorry for my delayed picture ![]()
Hi Erol,
thanks for the picture. Looks as we are using the same wiring. The only real difference I see is that the sticker on the IC says V2.34 while yours indicates V2.00. That might explain why not all all Ritto 4630/01 behave the same.
best regards
Patrick
Yeah, meanwhile on firmware 1.2.2. the opener is broken again. I hope Nuki can give me opportunities to bring the opener to its last version 1.2.1.
The problem is not the speaker unit itself, but the transformer that is mounted on the central panel. There are vastly differing systems out there in the wild and the Openers standard “Ritto” profile is not yet compatible to all of them.
I’m going to send you some instructions via PM on how to make 1.2.2 work with your Opener.
Hello PatrikB78,
you wrote at RITTO 4630/02 success with a pre-beta. What is with your Ritto 4630/01?
Thank you very much.
Thanks for your hint. My fault. I was talking about my 4630/01.
Hello @Juergen,
when is the release date of that pre-beta?
The new firmware repairs the Open function via App for the Ritto 4630/01. But ring to open is farther broken.
Hi Erol,
thank you. What new firmware do you mean?
1.2.4
If beta testing goes well within the next weeks.
Hello @Juergen,
do you have some news?
New firmware release is scheduled for this week. 4630 support has much improved: Most systems work out of the box with default settings, some need special parameters (Nuki support can help).
Thanks @Juergen !
Today I came to test it finally with my 4630/02.
It does work much better than before. So it recognizes the ring (which did not work before). I followed the wiring instruction and made sure it’s correct twice.
Anyhow, it can not open the lock at the gate (the button on my ritto works though). Also, I tried the 2-persons variant to configure it but it didn’t help either.
What else could I do to to configure it?
Btw, others in my compound use newer phones at the same bus. (If that makes any difference).
Any help is greatly appreciated, I believe it’s only the last bit of modification.
Ich habe es heute auch mal an meiner 4630/2 getestet.
Beim Einrichten erkennt Nuki das drücken des Türöffners an der Sprechanlage aber nicht das klingeln an der Haustüre und kann die Türe auch nicht öffnen.
Opener Software 1.2.6
Habe heute die Opener Version 1.2.7 installiert.
Einrichtung:
Der Opener erkennt das Drücken des Türöffners an der Sprechanlage und das Klingeln an der Haustüre.
Die Türe kann aber weder durch die App noch per klingeln geöffnet werden.
I’ve changed the delay (Settings → Administration → Delay when opening [might be slightly different in english. On german it is “Verzögerung beim Öffnen”]) to 3 seconds. Since then Ring-To-Open works quite smooth ![]()
