j-fraga
(Joao)
February 11, 2026, 8:31pm
1
I am using a Smart Lock Pro (4th Gen) running firmware version 4.8.6, connected to a Mosquitto MQTT broker (over Thread).
According to the Nuki MQTT API v1.5, the device should publish to the lockActionEvent topic whenever a lock action is about to be executed.
Therefore, I monitored the topic nuki/<REDACTED>/lockActionEvent, performed the following actions, and recorded the payloads:
Actions via
Lock
Unlock
Android app (Bluetooth off; Nuki reachable via Thread )
2,0,912,0,0
1,0,912,0,0
Android app (Internet off; Nuki reachable via Bluetooth )
2,0,912,0,0
1,0,912,0,0
Nuki Web
2,0,123838,0,0
1,0,123838,0,0
MQTT
2,172,0,0,0
1,172,0,0,0
Matter triggered (Home Assistant)
(no message published)
Observations :
Matter-originated actions do not trigger a MQTT lockActionEvent publication.
The MQTT lockActionEvent payload does not provide a way to distinguish whether an action was triggered via Matter, Bluetooth, or Wi-Fi.
Are these indicative of limitations in the current firmware?
Juergen
(JĂĽrgen Pansy)
February 12, 2026, 4:54pm
2
Looks like a bug. There is a trigger for Matter based lock actions, so they should also be reported. Thank you for pointing it out, we’ll look into it.
According to the current spec Matter is a separate trigger, but Bluetooth/WiFi/Thread are not. If you want these you’d need to create a new feature request. Just fyi - the value add of it is relatively limited, because the Apps will choose whichever channel works best for them at the moment. i.e. a lock command from an App triggered via Thread does not necessarily mean that the user has been remote.
DanielLO
(Daniel Labrador Orellana)
February 26, 2026, 5:48pm
3
The bug regarding Matter based action not triggering a MQTT lockActionEvent has now been resolved in our latest Beta 5.7.5 .
We would appreciate if you could give it a try and come back to us with your feedback.
Thanks for your support.
j-fraga
(Joao)
February 27, 2026, 5:58pm
4
Hola Daniel,
I’m using the Smart Lock Pro (4th Gen) , which is currently on version 4.9.2 . It seems version 5.7.5 might be specific to the 5th Gen hardware.
Unfortunately, even with the latest v4.9.2, the issue is still persisting and not working as expected. Could you look into this for the 4th Gen model please?
DanielLO
March 2, 2026, 11:50am
5
Thanks for your reply.
Smart Lock 4th Generation will also be available with this fix very soon.
Please stay tuned as I will let you know when the build is available
DanielLO
March 3, 2026, 1:49pm
6
Smart Lock 4th Generation build 4.9.3 with this fix is already available.
Please see:
Smart Lock (4th generation) Updates
Smart Lock Beta 4.9.0
(26.11.2025)
Enhanced logging for Beta-user troubleshooting
Smart Lock Beta 4.9.1
(16.12.2025)
Minor improvements and bug fixes
Smart Lock Beta 4.9.2
(22.01.2026)
Minor stability improvements
Smart Lock Beta 4.9.3
(03.03.2026)
Main motor longevity enhancement
Matter based lock action triggers MQTT lockActionEvent
j-fraga
(Joao)
March 6, 2026, 9:13pm
7
It’s working. Thanks!
Here’s the updated table:
Actions via
Lock
Unlock
2,0,912,0,0
1,0,912,0,0
2,0,912,0,0
1,0,912,0,0
Nuki Web
2,0,123838,0,0
1,0,123838,0,0
MQTT
2,172,0,0,0
1,172,0,0,0
2,171,0,0,0
1,171,0,0,0
Regarding my other observation:
I have opened a feature request for that a few months ago (see bellow).
The rationale is that having an ID for Bluetooth separate from “system” can be useful for auditing, forensic analysis and troubleshooting.
MQTT API
Add three new trigger IDs, one each for Bluetooth, Wi-Fi, and Matter, to the next revision of the MQTT API (section 3.7 of the documentation)
In the current MQTT API v1.4, the /lockActionEvent does not differentiate between Bluetooth, Wi-Fi, and Matter connections. All of these connection methods are represented by the same trigger ID (0 – “system / bluetooth command”). This is unsatisfactory for auditing, forensic analysis and troubleshooting, where identi…
system
(system)
Closed
September 2, 2026, 9:13pm
8
