Smart Lock Ultra/Pro/Go Firmware Beta 5.7.x
Smart Lock Ultra/Pro/Go Updates
Smart Lock Beta 5.7.0
(10.12.2025)
  • Enhanced logging for Beta-user troubleshooting
Smart Lock Beta 5.7.1
(15.01.2026)
  • Minor improvements and bug fixes
Smart Lock Beta 5.7.3
(02.02.2026)
  • Minor stability improvements
Smart Lock Beta 5.7.4
(12.02.2026)
  • Improved unlatch mechanism
Smart Lock Beta 5.7.5
(26.02.2026)
  • Motor longevity enhanced for Smart Lock Go
  • KP2 pairing stability
  • Matter based lock action triggers MQTT lockActionEvent
If you have problems with the WiFi connection of your Smart Lock, please follow the advice in the FAQ before you post here in the forum.
Firmware 5.7.1 is on my Nuki Pro. So far, I haven’t noticed any negative issues. I will keep an eye on it and report back if I encounter any problems.
I’m bringing up the problem from version 5.6.X again, which still persists. I would still appreciate feedback or even a fix.
Since the Matter improvement introduced with version 5.5.4 (“All Smart Lock state changes are now consistently indicated”), I’ve noticed the following behavior: when I activate the Lock’n’Go function (in my case by pressing twice the button on the lock manually), I immediately receive an Apple Home notification saying “The lock XYZ was unlocked.” Then, when the door closes and Lock’n’Go locks it, I get another message saying “The lock XYZ was locked.”
What I mean is that since version 5.5.4, two notifications are sent via Apple Home when using Lock’n’Go — “unlocked” (which doesn’t make sense in this context) and “locked,” which is correct. Before version 5.5.4, only the correct “locked” notification appeared after locking, not already when the button was pressed.
Could this be fixed again in a future version, please?
Still Problems that the Pro stands in Unlatch Position
The Public Release 5.7.8 is finally available and being rolled out in stages over the course of the next weeks, thus this topic is closed.
The new development iteration has been kicked off with Beta 5.8.0, thus please use following topic to report your findings, insights and feedback:
