MQTT API: new trigger IDs for Bluetooth, Wi-Fi, and Matter
MQTT API
Add three new trigger IDs, one each for Bluetooth, Wi-Fi, and Matter, to the next revision of the MQTT API (section 3.7 of the documentation)
In the current MQTT API v1.4, the /lockActionEvent does not differentiate between Bluetooth, Wi-Fi, and Matter connections. All of these connection methods are represented by the same trigger ID (0 – “system / bluetooth command”). This is unsatisfactory for auditing, forensic analysis and troubleshooting, where identifying the specific connection method used to trigger an action is often crucial.
Since in the revision 1.5 of the MQTT API there’s an ID for Matter (ID 171), the above feature request needs to be revised as follows:
Add two new trigger IDs:
  • One for Bluetooth
  • One for WiFi
