About the MQTT category
The MQTT API allows to connect a Smart Lock to a server in the local LAN using the popular MQTT protocol.
The MQTT API was developed together with early adopters here in the forum and is available on all Nuki Smart Locks with integrated WiFi or Thread via Matter connectivity.
Goal of this category
Discussions around the usage of the MQTT API which utilizes the popular MQTT protocol in order to allow an easy integration of Nuki devices into local smart home hubs.
Latest version of the MQTT API documentation
MQTT API 1.6.pdf (278.9 KB)
Non-goals of the MQTT API
  • Connecting to remote MQTT servers
  • Substitute the connection to Nuki servers (Firmware update, Time update, Remote access)
Terms of Use
Thank you for using one of NUKI’s Application Programming Interfaces. By accessing or using our APIs, you are agreeing to the terms of use of the Nuki APIs.
