Smart Lock 2.0
Use magnetic sensor with Auto Unlock.
With the increased Bluetooth 5.0 range the door will start unlocking when I’m further away from the door. This is sometimes so fast that when I’m at the door I have to manually unlock it because it had latched again. The idea is to leave the door unlatched until de sensor detects the door open and closed again. This is similar (actually inverted) with the use of the magnetic sensor with Lock ‘n go.
Increasing the unlatch time can be annoying because then, when I’m already inside, I have to wait for the lock to latch before walking away from the door (wind could open the door while unlatched).
I live in an apartment and this feature would be great to keep the door unlatched until I’m really inside. Because of the greater Bluetooth 5.0 range the door unlockes too early so that when I finally arrive at the door I find it often latched again. Increasing the unlatch duration is unpractical because then we have to wait around the door to make sure it’s properly latched.
