Smart Lock (4th generation) Firmware Beta 4.6.x
Smart Lock (4th generation) Updates
Smart Lock Beta 4.6.0
(11.02.2025)
  • Enhanced logging for Beta-user troubleshooting
  • Bugfix to ensure proper handling of automatic lock actions during Night Mode
Smart Lock Beta 4.6.1
(18.02.2025)
  • Bugfix which ensures that no WiFi related errors are shown for a Smart Lock (4th Generation) which apparently has no WiFi built in
Smart Lock Beta 4.6.2
(26.02.2025)
  • Bugfix for failing lock’n’go action
Smart Lock Beta 4.6.3
(02.04.2025)
  • Matter 1.4 upgrade, including stability and availability improvements
Smart Lock Beta 4.6.4
(24.04.2025)
  • Matter 1.4 stability improvements
  • Adjustments on WiFi Compatibility mode
I am still on version 4.4.9, even though I have the automatic updates option validated
Hi Antonio, the same problem here !
Make sure that your locks are signed up for the beta: How to become a Nuki Smart Lock Beta tester
As 4.5.x has been released publicly, you might need to wait for this to arrive on your lock first. If you do not want to wait for the staged roll-out, you can manually update at any time with the Nuki app.
Hi there, I’ve updated my smart lock to the last beta version but wifi problem still there since last firmware of august to today. Smart lock connect correctly to access point (Cisco 3702) but connection life is about 1 minute or less then it never connect again unless I reboot it. I’ve tried everything, smart lock hard reset, played with the AP configuration but nothing change, at the same AP I’ve several devices connect (Shelly, bticino devices, Amazon echo, velux gateway, laptops, smartphones and so on) and the only issued device it’s the nuki’s one. I hope every time for a resolution from the firmware update but it never happened. Have you got some suggestions? Thank’you, cheers from Italy
Did you try to set the WiFi on your router to 2.4 GHz only?
Thanks to reply, the SSID where the smart lock is connected is only 2.4GHz working on channel 1 (2412MHz)
Although I hate to sound like a “DoesNotHelpYouDesk”: did you already tried to restart your WiFi router. How far is your WiFi router from the Nuki lock? I had to install an extra Mesh “tower” near my Nuki lock to get a strong enough WiFi signal.
Absolutely not Nuki related: I had an Eve Outdoor camera that really could “see” one of my Mesh “towers” through the window, which “disconnected” every other day. I replaced that camera for another Eve camera (which I used ant the back of my house) and that one keeps the connection.
I’ve tried everything, btw I haven’t a wifi router but an access point (Cisco 3702). AP and smart lock are about 4 meters far without anything between. Everything connected to AP works without any problem, the only one device with connection problem is the smart lock
With the update to iOS 18.4 is it possible to open the door without unlatch it? Should it be a function of matter 1.2 ?
Yes, it is a feature of Matter 1.2 and supported by the Nuki Smart Lock, but not (yet?) supported by Apple Home. As far as we know it is also not supported in iOS 18.4.
Initial post has been updated with the release notes of the new Beta 4.6.4
This Beta brings an update for the latest Matter 1.4 and adjustments on the WiFi Compatibility mode.
Please provide your feedback on the Beta via this thread
Keypad 2.0 (firmware 2.3.2) doesn’t after upgrade SmartLock Pro 4 firmware 4.6.4.
Matter doesn’t work with iOS 18.4.1 (cannot add device Matter)
Edit : Matter works after unplug Apple TV (homePod Mini hub Thread)
Hello Antoine,
Thanks for your feedback. I sent you a private message to elaborate on the issue mentioned regarding your Keypad 2.0.
A new Beta 4.7.0 is available, please install this Beta and provide your feedback in the respective Beta channel - thank you :pray:
