Smart Lock (4th generation) Firmware Beta 4.3.x
No - see in the FAQ here - Nuki The Smart Lock
Thanks, then I won’t risk installing 4.3.8 until the majority of users confirm the solution to the connection problems, which is my case.
Hi
Connected my smartlock pro 4.0 via matter
In the beginning it works fine but now the lid messages when someone open the door arrive very late
Did some exlierinece the same issue and how can I solve it ?
Using iOS and connected via Homey pro 2023
Original post has been updated with release notes for the Smart Lock (4th generation) Beta 4.3.9
  • This Beta fixes the known problems with Bluetooth or WIFI/Thread connectivity mentioned in the last beta release notes.
  • Remote access via Thread does produce less reconnects and should be more stable now.
This beta is supposed to be the final beta before the next release. Please report any problems you have with it.
One important note: There has been a configuration mistake at Nuki side, which can prevent some Smart Locks from automatically updating to 4.3.9.
If you have Auto-Update enabled and your Smart Lock did not yet update to 4.3.9 automatically, please do so manually with the Nuki App.
It would be nice if those who have installed 4.3.9 could confirm here that the connection problems have been solved.
I have installed beta version 4.3.9 on me SL4 and now in the last two days I have issue with the bluetooth connection, the smartphone and the fob could not connect to the lock. Remove the batteries solve the problem and the bluetooth start to work again.
I have no such issue with previuos beta versions.
I found that the issue was not due to connection problem or beta firmware, but was related to battery. The SL4 told me that the battery was at 56% but instead the battery was lower and the SL4 didn’t work correctly. I have replaced the battery with new one and now the bluetooth connection issue seems to be gone.
Ciao Simone hai sostituito la batteria in garanzia?
Ciao,
no utilizzo normali batterie ricaricabili. Le ho solo sostituite con batterie cariche.
The last beta has now passed all tests and has been publicly released as 4.3.10. The roll-out via automatic update happens in stages over the next few weeks. A manual update through the Nuki App is always possible.
This topic will now be closed. Thank you for the participation and the provided feedback during the beta phase. :pray:
The new Beta iteration 4.4.x has been started in parallel, thus please use following topic to report your findings and feedback: Smart Lock (4th generation) Firmware Beta 4.4.x
