Nuki Smart Lock (4th generation) Release Notes (public releases)
This is an overview of the latest Nuki Smart Lock (4th generation) public firmware release. You will always find the latest release on top.
Firmware 4.9.6
(18.03.2026)
  • Matter/Thread stability improvements
  • Smart Lock motor optimizations
  • Bug fixes and performance improvements
Firmware 4.8.4/4.8.5/4.8.6
(29.01.2026)
  • Update to Matter 1.4.1
  • Faster locking and unlocking via Bluetooth
Firmware 4.7.4
(10.07.2025)
  • Bug fixes and performance improvements.
  • Minor changes and improvements in the background ensure that the Smart Lock runs even more smoothly.
Firmware 4.6.7
(12.05.2025)
  • Enhanced stability with Matter 1.4 and improved Wi-Fi settings
Firmware 4.5.4 / 4.5.5 / 4.5.6
(13.02.2025/19.02.2025/03.03.2025)
  • Overall, we improved the stability of the Smart Lock.
  • We enhanced the reliability of Remote Access via Thread. For the Smart Lock Pro (4th Generation), we also enhanced the reliability of the built-in Wi-Fi module.
  • We also improved the strength and reliability of the Smart Lock’s opening function (pulling the latch). This ensures a proper operation.
Firmware 4.4.9
(28.11.2024)
  • Enhanced Wi-Fi settings for your Smart Lock Pro
  • Improving the reliablity of the Thread connection
Firmware 4.4.8
(13.11.2024)
Firmware 4.3.11
(18.09.2024)
  • Stability improvements for the Wi-Fi connection of the Smart Lock Pro
  • Enhanced MQTT connection stability, now supporting new Home Assistant states (open, opening)
  • Bug fix concerning the Bluetooth connection
Firmware 4.3.10
(21.08.2024)
Firmware 4.2.8
(16.04.2024)
  • Stability improvements for the Wi-Fi connection of the Smart Lock Pro.
  • Fix for a bug which caused delays on the push notifications and activity log synchronizations. This affected Smart Locks that are connected to Nuki Web via a Nuki Bridge.
Firmware 4.2.6
(03.04.2024)
  • The Matter Standard 1.2 distinguishes between unlocking and opening the door. With this firmware update, you can unlock your door without pulling the latch. For now, this new feature is only available in case you use Home Assistant as Matter Hub.
Firmware 4.1.8
(14.02.2024)
  • Smart Lock and Smart Lock Pro can now be also controlled from remote with the Nuki App using the Thread uplink from a Matter pairing
  • Rework of the overall connection handling
    • Internal handling of WiFi, used for Remote Access and the MQTT API
    • Additionally adding the capabilities for using Thread for Remote Access and the MQTT API
Firmware 4.0.37
(18.01.2024)
  • Improved LED signalization on the Smart Lock
  • Usability and stability improvements for MQTT
  • Performance improvements and bug fixes
Firmware 4.0.36
(18.12.2023)
Firmware 4.0.31
(23.11.2023)
    – Improved LED signalization on the Smart Lock
    – More accurate display of the battery state
    – Improved accuracy of scheduled actions
Firmware 4.0.28
(14.11.2023)
  • The Nuki Smart Lock turns your smartphone into a key
  • Open the door by swiping or fully automatically with Auto Unlock
  • Assign up to 200 access permissions
  • Includes convenient Activity Log feature: Check who comes and goes
  • Easy connection to existing Smart Home devices thanks to Matter
  • Optimized Power Pack for a longer battery life
This topic was automatically closed after 1 minute. New replies are no longer allowed.
