SL3P Debug Mode broke (?) Bridge
I had the Bridge running since around two months together with an SL3P.
Bridge was used 99% for HTTP Calls from my Loxone Smart Home.
In preparation for the MQTT Beta I activated the SL3P Debug mode in the night for the first time (AND I missed to disable it). This morning the SL3P Battery was empty (Before it had ~ 37%) and the Bridge refused various HTTP Calls with the existing Token.
Although I had nothing more changed, in the Discovery Page I got exactly this situation the whole day:
If discovery is disabled via /configAuth or through the Nuki App, the IP is 0.0.0.0 and the port 0. In this case the /auth command fails with HTTP error 403.
I tried to use /configAuth [1/0] for the first time, but nothing changed.
A few hours ago I decided - and it was possible - to send an /factoryReset.
After that I paired the Bridge with the App, but I still only got:
// 20230110192920
// https://api.nuki.io/discover/bridges
  "bridges": [
  "errorCode": 0
Did someone experienced something similiar?
P.S.: With regard to the heavy drained battery: I didnt had activated the Status LED
Habe die Bridge nun auch nochmal in einem anderen Raum angebunden, in dem auch ein anderes Access-Point Modell hängt (Nur zur Sicherheit, auch wenn ich natürlich bereits die gesamte Infrastruktur durchgebootet habe…)
Is 212.227.31.40 the API Backend Endpoint from Nuki?
inetnum: 212.227.30.0 - 212.227.31.255
netname: IONOS-SHARED
descr: 1&1 IONOS SE
country: DE
org: ORG-SA12-RIPE
admin-c: IPAD-RIPE
tech-c: IPOP-RIPE
remarks: INFRA-AW
remarks: in case of abuse or spam, please mailto:
status: ASSIGNED PA
notify:
mnt-by: AS8560-MNT
created: 2008-11-25T12:55:52Z
last-modified: 2020-11-30T17:13:43Z
source: RIPE
Seems so:
Mabe you discovered a problem in the beta with activating the mqtt API (which requires WiFi) while the SL3P is connected to a bridge (and the internal WiFi is off). I’ll forward this to the firmware team.
Inbetween i’d recommend to not activate the mqtt API (= debug mode) while the Smart Lock is connected to a bridge.
To recover the bridge you need to set it up and pair it with the Smart Lock again through the Nuki App > Manage Devices > Add Bridge section. You could also activate and set up the HTTP-API through the App and don’t need auto-discovery in this case.
Thanks for the insights - Important to know also for the FW Teams: The SL3P was on FW 3.4.10, I received the Beta Confirmation “only” today from the Support (and will install the Beta soon)
Good to know, Thanks.
Before I will run this setup (Beta [+ MQTT] without the Bridge) I have to find a “maintenance” window to make sure, that I will not run into the “UniFi Problem” some users are reporting apparently
I did the repair already yesterday evening, but still not successfull output in the Auto-Discovery.
But, I wasnt aware that the HTTP-API can also be activated through the App, which I have now found (was not intuitive) and finally I have back HTTP-API Access, Thanks!
P.S. Maybe you can add an small “i” (Info) Icon next to the those product icons:
… which does not have the MQTT API, therefore it could not cause the battery drop anyway. I double checked with the team in between and there is no problem with enabling debug while SL3P is connected via bridge only, even on the latest betas.
