Any regarding the Integration of DS2010 Video?
Cut Loudspeaker (not ground side) and connect PCB side to red/yellow (ring detection)
Connect other side of to green (for ring suppression)
Via next to dip switches connects to blue (open button)
Via labeled Gnd connects to black and violet (ground)
Great, thx! ![]()
I will give it a try. I think I will conenct the SKS an the Opener with a plug (Molex maybe) to disconnect it easily. I will give you feedback when Iâve tried it.
Please do post results once you got a chance to try this out - much appreciated!
nice! thank you!
so this is the loudspeaker pcb from HT4600 right?
does this only enable âring to openâ or is this able to control the open signal without any ring?
if so, it would be interessting how it could handle multiple doors.
am i right, that this pcb can be connect just in parallel on the bus to existing intercoms?
My Opener works with SKS HT4600 cabled like shown on the photo from @Panda. But actually just the open function. Ring detection doesnât work yet. I am working on it. I configured my System as âGenericâ>âAnalogueâ.
so you are able to just randomly send an âopenâ signal without any ring being there?
Thanks a lot for the response! So did you have to irreversibly modify anything to achieve this so far, or were you able to kind of âhookâ into it?
I didnât have any hopes that anything would work, so I just left my HT4600 untouched, but now I might just give this a try as well. ![]()
When I ring my bell manually by pushing the button next to my door I can open the door with the opener. But the opener donât detect the ring. I think the cabeling is wrong? There is the yellow wire to the speaker and a black wire from the speaker (and all other components in the phone, so it have to be GND). I will draw my cabeling later and post it here. Maybe someone sees the mistake.
I cabled it like shown below and described by @Panda. Why do the Ring detection not work correctly? Someone an idea? The installation guide in the App says, that I have to connect the orange cable with the mic. But I donât know what it should be used for.
You need to contact Georg_S as I have written in my other post for the il vetro. He has to enable analog detection on your Opener. It is not available as a setting to the end user.
Okay, thx! I wrote him a few minutes ago because first I didnât read that little but important information. Then I will spend my time with soldering it propperly.
IT WORKS!!! SKS HT4600 with Nuki Opener as âGenericâ>âAnalogueâ. I donât know if @Georg_S programmed my Ring Detection in the last hours or if it works without any changes from an admin. But here are some pictures:
My Adapter âNuki to Molexâ
SKS HT4600 with Molex soldered to PCB and Speaker-Contact
My installation
I would recommend to let more spare cable to the Opener or using a much more little plug than molex. It was very hard to close the case. I wanted to use a plug because it is not my own flat and i want an easy way to deinstall the opener. If you want you can solder the Opener cable directly to the PCB.
THX @Panda and the others here to find a solution together! If SKS would talk to Nuki (or otherwise) to support this series officialy it would much greater than this DIY solution, but for me it is really ok!
Hey @DominikZ , thanks a lot for reporting your results here!
Just a couple of questions that would be great if you could clarify. ![]()
My understanding is that you cannot trigger opening the door without ringing the bell first, right? Or can you also simply go to the app and hit âOpenâ and it will buzz you in right away?
So if thatâs the case, how has your experience with the âring to openâ feature been? Does it work reliably with this approach?
Just want to make sure itâs worth it before I get to soldering.
Thanks a lot!
Hi!
Correct! Iâve read some SKS manuals to check this function but all of them say you have to ring the bell first before you can open the door. It has nothing to do with the functionality of nuki but with the configuration of the HT4600 by SKS. Also you canât open the door by pressing the button on your HT4600 without a bell rang before.
Ring-to-Open works perfectly! When I leave the house to walk around with my dog I press the button on the Opener to activate Ring-To-Open and when I come back I ring at the door an Nuki opens the door. Also the Geofencing Ring-to-open works great. Iâve checked it some times and everytime my door was opened by nuki. Also with my brother (I set him up as user for my nuki products). And last but not least, when I ring my bell i can open the door with the app.
Since Update to Version 1.4.4 of the Opener, everytime I push the Button on the Opener, the loudspeak of the SKS sounds electric. I think there is a fault within the update. Anyone ideas or the same problem?
+1 HT 4500/3, please!
Kann die Anleitung von @Panda und @DominikZ bestätigen, vielen Dank dafßr!
Die Verkabelung passt und mit Generic + Analogue ist der Opener voll funktionsfähig.
Mit der neuesten Software war auch alles out-of-the Box funktionsfähig.
Anbei finales Bild der Zielverkabelung.
@Panda, @DominikZ, @flymg is something similar with the HT4500/3 possible? Any kind of documented workaround somewhere? Soldering wouldnât be a problem for me.
I just followed the manual of @Panda . I donât know something about other models of SKS, sorrry.
