I prefer to address my Nuki 4 pro lock via LAN network.
I tried an example: http://192.168.1.50:8080/lockAction?nukiId=1&deviceType=0&action=3&token=123456 but it gives me connection denied error.
Help is much appreciated!
Do you have a bridge? From my understanding local API is only supported using the Bridge. MQTT might be an option as this seems to be integrated in the lock directly (no experience yet).
Correct. The Smart Lock 4th gen Pro does have a local MQTT API, which requires to have an MQTT broker in your network.
The API call you tried to send was to the HTTP-API of the bridge, which only works with SL4G if you connect a Nuki Bridge to it.
Ok , thanx guys.
I have a look into MQTT.
I can always stick to the api.nuki.io/smartlock…
