Our Goal:
We are operating a practice room booking system.
Our goal is to automatically create time-restricted PINs for customers who have booked a room.
- We generate a 6-digit PIN.
- The PIN should become valid 15 minutes before the booking start time.
- The PIN should expire immediately after the booking end time.
- We send this PIN to the customer by email.
To do this:
- We use the Nuki Bridge HTTP API (on local network, port 8080).
- We are sending requests directly to the Bridge to create type: 13 authorizations (keypad PINs).
Current Issue:
- Bridge at
192.168.0.95is not responding on port 8080 (timeout) - We suspect the Bridge’s IP address has changed or it has disconnected from Wi-Fi
- We do not need remote access via Nuki Web — this is a local-only integration
Setup Summary:
- We are using a Nuki Bridge to create and manage PINs for Keypad 2 via the local HTTP API (port
8080on LAN). - Our backend server communicates directly with the Bridge using its local IP and token:
curl "http://192.168.0.95:8080/info?token=167392"
- This setup was working previously, but now consistently times out with:
curl: (28) Failed to connect to 192.168.0.95 port 8080: Connection timed out
- We are using Docker with
network_mode: hostand have confirmed the timeout occurs even outside Docker.
