The Nuki Bluetooth API allows local control of Nuki devices via direct Bluetooth communication.
Goal of the Bluetooth API
The Nuki Smart Lock & Opener Bluetooth API allows to locally control devices directly via Bluetooth. This allows simple integrations based on specific applications running on Bluetooth enabled devices which are located within range to the paired Nuki device.
Latest version of the Bluetooth API documentation
Nuki Smart Lock Bluetooth API 2.3.1
Nuki Opener Bluetooth API 1.1.1
Terms of Use
Thank you for using one of NUKI’s Application Programming Interfaces. By accessing or using our APIs, you are agreeing to the Terms of use of the Nuki APIs.
