Yes, look at this post: Nuki Opener | Golmar T-940 Plus - #19 by Juergen
Hi. I have golmar platea plus and I installed nuki and it works perfectly. Even with 0 seconds delay. The only limitation is that only works if I ring before.
That’s because these digital systems needs to be activate to open the door. It’s a shame that I need to ring my system before the nuki could open the door. It’s like it hasn’t control over the golmar.
I find a possible solution that you nuki guys could investigate. In platea plus there’s a option to see the camera and open the door. It’s the third bottom (without anyone in the street rings).
If nuki could activate this option it’s the solution…
what do you think???
Yes, this could be an option to overcome the" ring before open" limitation. Feel free to add a feature request and start collecting votes for it
Done, please let me know if it makes sense:
I can’t get past the configuration steps… how did you do it?
Hola Javier,
Any chance you could upload a picture of the final wiring? I am super stuck.
Hi, did you solve this issue?
I connected the golmar plus according this diagram.
Doesnt work al all.
What system do you select? Generic analog or a specific golmar. Any tips?
Also interested if you solved your issue. Openjng before ringing. Otherwise this entire systemdoesnt make sense.
Thanks, jj
Hola Javier, me decir como lo hiciste? Yo no entiendo nada de la solución que dan ellos.
Muchas gracias de antemano.
Saludo Roser
