Be able to open door before ring on BUS based systems
NUKI opener
Currently is only possible to open the main door of a building on BUS based system only when the intercom is activated after button or code combination is pressed in the front door panel.
It will be much better if it will also work without the need of a previous ring.
For instance for the proximity function to work otherwise if someone is approaching the front door with full hands won’t be able to open easily.
Stated above
