Bridge HTTP-API
The Nuki Bridge HTTP API allows local control of connected devices via simple http calls.
Goal of the Bridge API
The Nuki Bridge API allows to locally control devices that are connected to a Nuki Bridge. The bridge forwards incoming API calls via BLE to the Smart Lock or Opener and can also call callbacks when the Nuki device reports state changes. It allows a simple integration into local smart home hubs.
Latest version of the Bridge API documentation
Bridge API 1.13.3
Non-goals of the Bridge API
  • Connecting to remote bridges
  • Substitute the connection to Nuki servers (Firmware update, Time update, Remote access)
  • Administration of a Nuki Smart Lock or Bridge
Terms of Use
Thank you for using one of NUKI’s Application Programming Interfaces. By accessing or using our APIs, you are agreeing to the Terms of use of the Nuki APIs.
