With the latest Beta firmware versions 2.7.0 and 1.17.1 you can now:
get the battery in % for a Smart Lock (experimental)
(needs Smart Lock Firmware 2.8.1/1.10.0 or higher) -
get callbacks for door Opener ringactions which did not trigger a state change (“someone unknown rang the bell”)
(needs Opener Firmware 1.5.1 or higher) -
get the Keypad battery state
(needs Smart Lock Firmware 2.8.3/1.10.1, Opener Firmware 1.5.2 and Keypad Firmware 1.7.0 or higher)
Examples:
/lockState
Smart Lock:
"mode": 2,
"state": 1,
"stateName": "locked",
"batteryCritical": false,
"batteryCharging": false,
"batteryChargeState": 85,
"keypadBatteryCritical": false,
"success": true
Opener:
"mode": 3,
"state": 3,
"stateName": "rto active",
"ringactionTimestamp": "2020-04-27T16:13:00+00:00",
"ringactionState": false,
"success": true
Callback:
Smart Lock:
(added batteryCharging, batteryChargeState and keypadBatteryCritical)
{“nukiId”: 11, “deviceType”: 0, “mode”: 2, “state”: 1, “stateName”: “locked”, “batteryCritical”: false, “batteryCharging”: false, “batteryChargeState”: 85, “keypadBatteryCritical”: false
Opener:
(added ringactionState, ringactionTimestamp and keypadBatteryCritical)
{“nukiId”: 11, “deviceType”: 2, “mode”: 3, “state”: 3, “stateName”: “rto active”, “batteryCritical”: false, “ringactionTimestamp”: “2020-04-27T16:13:00+00:00”, “ringactionState”: false, “keypadBatteryCritical”: false
The update will be done autonatically if your Bridge is part of the Beta program.
Please test it out and give us your feedback!
