Here we go again … We evaluated and described the problem several times already. I even provided possible and rather simple solutions. Just acknowledge the problem and solve it, I don’t see how you need more data for this.
I have the exact same problem and the same solution came into my mind, that is described here: Simply make the timeout period configurable in the experts settings. That’s it.
Yes, it might interfere with some customers, potentially on the cost of comfort. But we are talking about a (smart) lock here, which primary use case is all about security.
Just yesterday my wife came home with my son, auto-unlock didn’t work so she opened the door manually via the app and 6 minutes later her phone triggered auto-unlock, resulting in an open door late in the evening. This really sucks and needs to be solved somehow.
Yes. And the way to this new feature was described two years ago. ![]()
I opened this thread 2 years ago and it took the devs 5 months for a non-answer.
Sure. It’s a feature request and needs to be voted for. ![]()
More votes = higher probability of being implemented
[quote=“hosch, post:45, topic:8689, full:true”]
More votes = higher probability of being implemented[/quote]
A feature request to fix a potential security issue, but the devs are being too German to recognize this unless it’s being pushed on the proper channels. After all, everything has to be in order in this country, we can’t have people interrupt the system, because this would harm the safety of the system. Oh wait, that’s why we opened this thread in the first place!
I too have reported the problem several times to support as suggested by the administrators but without having an intelligent and functional solution to the problem. it happens that the door doesn’t open and I have to open with the 2.0 keypad, and after a few minutes the door opens again. Truly ridiculous.
I also face the situation that the door opens a couple of minutes (or when I unlock the phone after a while) after I have already opened the door by the Keypad. Same situation with my wife’s phone. All settings are set correctly and the unlock check is OK. It is a bit frustrating that the door does not open while stepping to the door but after you have already opened and entered the house the door opens by itself unexpected, and worst case unnoticed.
Not sure what is the reason for this behaviour especially since this does not happen always. Sometimes the Auto unlock work as expected. Next day it doesn’t work. The battery setting is set to medium and the detection is manually set to Nuki Power Pack.
Hope the Nuki Team can track this.
Cheers,
Emanuel
Please contact our support via the Nuki App (Menu > Help > Contact Customer Support). Only this will generate necessary logs for debugging your problems.
This is indeed a very serious problem that we have faced several times now. It happened more than once that our front door was left completely open all night long. The reason was that Auto-Unlock didn’t work again and the door had to be opened manually. Some time later, Auto-Unlock opened the door unnoticed.
The cases are increasing and it is only a matter of time before insurance companies find out about this massive security gap and Nuki locks are no longer covered by insurance.
This issue must be addressed urgently, otherwise the economic consequences for the Nuki company would be serious!
Totally agree. Meanwhile we have switched off Auto Unlock function (which is one of the most valuable features of the Lock) completely. Not sure if I/we are the only ones facing this issue. It is still unclear if it is caused by the APP or the Lock itself. After several chats with the Support Team and different changes in the APP and deleting cache till a complete reset of the Lock we decided to switch the function Off due the fact that Auto Unlock is not reliable (for us).
Cheers.
Emanuel
