exactly and if you go little bit more up, there also screen how to connect the intercom.
and as georg mentioned, it should work now without sending an invitation to georg with the latest firmware (version 1.6.4) of the opener. so probably you can choose now the abb/busch jaeger intercom in the setup.
should be in brand: generic or abb/busch jaeger
you have to try it out.
It happens to me like @palvarez and it seems that I have an ABb Welcome similar to his.
I have tried with the combinations of cables that they indicate, and I get that the intercom works, but the opener does not detect when they call
I follow the post from months and in the past @Georg_S run the initial config but for me was imposible it work.
My ABB is like yours Ivan I think. Did you connected red to A and black to B? I have exactly the same connections as you. And my ABB works ok but opener cannot be configured…
Let’s see if @Georg_S has any clue about it and help us
for the opener configurator finish to work and detect it I had to reverse the red wires to B and black to A. but when calling the telephone the opener never finds out. I have also configured it as that the telephone requires activation since it must be called before giving the open button, but without success either. Please, any test you can think of is welcome
Ring detection is still not working properly on the ABB Systems, as part of the signal at the end of the ring signal is encoded and keeps changing. We could try lowering the relative comparison range for the signal, but this may result in unwanted ring detections (e.g. from your neighbours)
I think that @Ivan_Garcia_Corroto, @palvarez and I have the same ABB Welcome video handsets in our homes.
If you need extra testing or mesurement of signal let me know and I will help. I work in IT segment so maybe I can help you guys giving support for this equipment.
Hi Ivan,
the reason why you have to do that is because our ABB Welcome ignore polatity of cables but opener does not. To be more Opener compilant I changed the instalation cables from A to B and viceversa, now the Opener cable are in place.
Exactly @dushu, i have the same intercom. I tried to change the connection of the Opener cables: black to A and red to B as @Ivan_Garcia_Corroto suggests, but still not working…
