You can use our API to directly push bookings from a calendar per day.
(Note: It is not possible to enable several different time windows for one day at once atm!)
Authenticate
See Authentification. Use the access token as e.g. ACCESS_TOKEN.
Preliminary Remarks
Even if you just want to have keys valid for some hours a day the allowedFromDate has to be set to restrict an authentication to specific times and dates!
allowedUntilDate should also be set to avoid unwanted valid keys in the future, as they will not be removed - just overwritten - in the specified process.
date format = YYYY-MM-DDTHH:MM:SSZ
(You can also use YYYY-MM-DDTHH:MMZ)
allowedUntilDate can be left empty to set no end date.
Days are set via bitmask:
| Day | Bitmask | Value |
| Monday | 01000000 | 64 |
| Tuesday | 00100000 | 32 |
| Wednesday | 00010000 | 16 |
| Thursday | 00001000 | 8 |
| Friday | 00000100 | 4 |
| Saturday | 00000010 | 2 |
| Sunday | 00000001 | 1 |
e.g. Monday + Wednesday + Friday = 64 + 16 + 4 = 84
Not setting a value also allows all weekdays.
Time restrictions are set as “minutes from midnight”, e.g.:
| Time | Minutes | |
| 08:00 | 8 am | 480 |
| 11:00 | 11 am | 660 |
| 17:00 | 5 pm | 1020 |
| 19:00 | 7 pm | 1140 |
Example call:
curl -X POST --header 'Content-Type: application/json' --header 'Accept: application/json' --header
'Authorization: Bearer ACCESS_TOKEN' -d '{ \
"allowedFromDate": "YYYY-MM-DDTHH:MMZ", \
"allowedUntilDate": "YYYY-MM-DDTHH:MMZ", \
"allowedWeekDays": WEEKDAYS_BITMAP, \
"allowedFromTime": MINUTES_FROM, \
"allowedUntilTime": MINUTES_TO\
}' 'https://api.nuki.io/smartlock/SMARTLOCK_ID/auth/KEY_ID'
Case 1: Fixed time
A band books a rehearsal room every monday from 7pm to 10pm for the whole year 2019. We will set their access key once. And we give them 5 minutes grace period to enter and leave the room.
"allowedFromDate": "2019-01-01T00:00Z", \
"allowedUntilDate": "2019-12-31T23:59Z";, \
"allowedWeekDays": 64, \
"allowedFromTime": 1135, \
"allowedUntilTime": 1325 \
Case 2: Flexible schedule
Our rehearsal room can be booked from day to day by calendar. We don’t want to set up new keys for returning users as this would not be feasable. The idea is to instead push keys for the next day every night.
You can achieve this via 2 different ways:
Example 1: Monday, 7th Jan 2019, 7pm - 10pm with grace period:
curl -X POST --header 'Content-Type: application/json' --header 'Accept: application/json' --header ' Authorization: Bearer ACCESS_TOKEN' -d '{ \
"allowedFromDate": "2019-01-07T00:00Z", \
"allowedUntilDate": "2019-01-07T23:59Z", \
Example 2: Thursday, 8th Jan 2019, 10am - 11am with grace period:
curl -X POST --header 'Content-Type: application/json' --header 'Accept: application/json' --header 'Authorization: Bearer ACCESS_TOKEN' -d '{ \
"allowedFromDate": "2019-01-08T09:55Z", \
"allowedUntilDate": "2019-01-08T11:05Z" \
With example 1 being more flexible overall.
For even more complex usecases we suggest you contact us for a full Short Rental Integration.
