Web API Authentication
This is part of the Nuki Web API documentation.
Successful API calls require appropriate authorization: The bearer token (also see Bearer Authentication | Swagger Docs) needs to be present in each request to the API. There are several ways on how to obtain a valid bearer token, which we will describe in the upcoming section.
Curl call from the Swagger example:
curl -X GET --header 'Accept: application/json' --header 'Authorization: Bearer
c2c0981ffcab78eecd13c8b7ae9fdec4706045bdbb17b1ef06a335b832f36641322c5c3357b7fe47'
https://api.nuki.io/smartlock'
When to use which type of Authentication?
Type Usecase
API Tokens When you use the API to access your own Nuki Web account with your own Smart Locks only.
OAuth2 When you are offering an application to your users which grants your server/application the right to operate the Smart Lock of a user.
When your users have no technical experience and you want to offer a simple login to your services without the need for the user to generate API tokens and copy them around.
When you need short term access to a users Nuki Web information for your (mobile) web app. In this case use the implicit authentication flow.
API Tokens
Log into your Nuki Web account, go to MENU > API and create a new API Token. Use this API Token as Authorization Bearer:
Copy the API token into the clipboard and store it in a secure way. It gives permanent access to all rights you did grant to it:
Use it as the Authorization: Bearer in your API calls:
curl -X GET --header 'Accept: application/json' --header 'Authorization: Bearer API_token' 'https://api.nuki.io/smartlock'
API tokens do not expire, but they are destroyed when the password of the corresponding Nuki Web account changes.
OAuth 2
We support the Authorization grants “Code Flow” and “Implicit”. When using “Implicit” the access token expires after one hour.
If you follow the “Code Flow” scheme you will need a client secret in order to receive an access token. Client secrets are issued only by Nuki. Please apply via Nuki Web to get yours.
For an introduction to OAuth 2 have a look at this:
Code Flow - OAuth 2 Authentication Example
1. Authorization Code Link
https://api.nuki.io/OAuth/authorize?response_type=code&client_id=CLIENT_ID&redirect_uri=CALLBACK_URL&scope=SCOPES
CLIENT_ID is your OAuth 2 API Key from Nuki Web > MENU > API
CALLBACK_URL is your callback URL to which users will be redirected after they successfully logged in. This field is mandatory in the code or implicit flow, so the CALLBACK_URL has to be restricted by inserting it into Nuki Web > MENU > API > OAuth 2 Redirect URL. You can add several URIs as comma separated values.
SCOPES is a list of scopes that you want to request from the user for your application. You can see which scope is needed for which API command on the Swagger frontend at https://api.nuki.io.
All parameters need to be URL encoded (Online URL encoder/decoder).
Example Authorization Call:
http://api.nuki.io/OAuth/authorize?response_type=code&redirect_uri=https%3A%2F%2Ftest.com&client_id=v7kn_NX7vQ7VjQdXFGK43g&scope=account%20notification%20smartlock%20smartlock.readOnly%20smartlock.action%20smartlock.auth%20smartlock.config%20smartlock.log
2. User Authorizes Application
3. Application Receives Authorization Code
Your user will be redirect to the provided callback URL:
CALLBACK_URL?code=AUTHORIZATION_CODE
Redirect URL from the example above:
https://www.test.com/?code=d69dc5bdfbae822707a3bbc3a8ea2f1a9f6053d5%7C1517592822654
4. Application Requests Access Token
Your application/server posts to the following URL to receive the final access token:
curl -X POST -d “client_id=CLIENT_ID&client_secret=CLIENT_SECRET&grant_type=authorization_code&code=AUTHORIZATION_CODE&redirect_uri=CALLBACK_URL” https://api.nuki.io/OAuth/token
CLIENT_SECRET is your client secret received from developer@nuki.io.
5. Application Receives Access Token
You will receive something like this as response from the server:
{"access_token":"ACCESS_TOKEN","token_type":"bearer","expires_in":2592000,"refresh_token":"REFRESH_TOKEN"}
You can use this ACCESS_TOKEN to make requests to the API in the same way as with API token authentication:
curl -X GET --header 'Accept: application/json' --header 'Authorization: Bearer ACCESS_TOKEN' 'https://api.nuki.io/smartlock'
6. Token Refresh
After your access token expires you will receive an “Invalid Token Error” from the API. You can use the REFRESH_TOKEN received in step 5 to get a new ACCESS_TOKEN by posting the following URL:
curl -X POST -d “grant_type=refresh_token&client_id=CLIENT_ID&client_secret=CLIENT_SECRET&refresh_token=REFRESH_TOKEN” https://api.nuki.io/OAuth/token
REFRESH_TOKEN is your refresh token received together with your last access token (step 5)
Implicit OAuth 2 authentication example
https://api.nuki.io/OAuth/authorize?response_type=token&client_id=CLIENT_ID&redirect_uri=CALLBACK_URL&scope=SCOPES
See the example of the “code flow” authorization for a detailed description of the parameters.
Same as with “code flow” authorization
3. Receive Access Token Via Callback URL
Your user will be redirected to the provided callback URL:
CALLBACK_URL?token=ACCESS_TOKEN
Your application needs to extract the ACCESS_TOKEN from the URL and can afterwards use this ACCESS_TOKEN for up to one hour to make requests to the API in the same way as with API token authentication:
This topic will contain a table of contents
Unfortunately, we only receive this answer in step 5:
{"access_token"=>"2bf2...", "refresh_token"=>"5c08...", "token_type"=>"Bearer", "expires_in"=>3600}
We use the client_id & client_secret that we received from developer@nuki.io. What could be the reason for this?
So you send an OAuth request for a user and log in with their Nuki Web credentials and get back only the tokens without information which user it was?
Yes. We use the code we get in step 4. We tried two accounts, both with the same result. This is our call in step 5:
curl -X POST -d "client_id=yQ_-...&client_secret=KInb...&grant_type=authorization_code&code=2fd0...&redirect_uri=http%3A%2F%2Flocalhost%3A3000%2F..." https://api.nuki.io/oauth/token
Looks good to me. Please be sure to check with the latest online-version of the doc at
https://developer.nuki.io/page/nuki-web-api-111/3/#heading--code-flow-oauth2
I will check if there is any outdated stuff or error in this original topic here.
@rvfx There was indeed an error in the documentation I fixed now. Thanks for getting back to us, so we could change this to avoid confusing for all future users.
I hope everything is clear now; else you can always contact me with further questions.
Thank you for your update! The problem that the token is only valid for one hour remains unaffected. We now help ourselves by performing a token refresh before each call.
Ah, sorry. I missed that you also reffered to this as a problem.
And yes, you are doing it the correct way.
Updated the new process to apply for an OAuth2 client secret:
Hi, is there any documentation on how long the access token and refresh token are valid for?
The token is valid for 1 hour. This is also stated in the token response.
The refresh token is always valid as long as it is not invalidated by another login.
In general, we use the conventional OAuth2 workflow here, which is why there is currently no further documentation om it.
Hey Stephan,
what do you mean by “invalidated by another login.”? Does this mean, whenever we log-in in the Web-Frontend we lose the refresh token? Or do we lose the token whenever the OAuth-Flow is invoked by the same credentials?
can’t start wit 12 and not use 0…
less brute force hack options, and a medieval idea of code.
Why?
you used an integer as code instead a string? i can’t understand.
Anyway i have bought Nuki’s as a backup system for opening. I have to provide 2 different code to guests because this limitation.
Yes, for security purposes the KP code cannot start with 12… and there is no ‘0’ on the KP. Could you please elaborate your question as to why you are providing two different codes to the guests?
whar security upgrading can be retrived by less numbers mutation?
i mean that i using Nuki as Backup system of another one, that can have 6 digit code 0-9 numbers.
It avoids most people from using their birthday as the passcode. It is also a design decision that Nuki has taken, in order to fit the “back” button into the keypad appealingly.
I’m trying to implement OAuth2 and I have tested both code Flow and Implict types.
I use the same Authorization Code Link but in one case I use response_type=code and in the other case i use response_type=token.
If I use code as response type everything is correct and on the callback page I can take from the querystring the result autentication code but in the other case the querystring does not start with ? but it start with # and server side I’m not able to read the value.
Do I miss something ?
This is by the design of the implicit flow.
In the Implicit Flow, the access token is returned directly in the URL fragment (also known as the hash fragment), which is the part of the URL after the # symbol. This is done for security reasons, as URL fragments are not sent to the server when making requests, thus keeping the access token out of server logs and potentially insecure network traffic.
On the other hand, the Authorization Code Flow returns an authorization code in the query parameter, which can then be exchanged for an access token securely on the server side.
The Implicit Flow was initially designed to be used in scenarios where the client application is running entirely in the browser, and it doesn’t have a server-side component that can securely handle the authorization code exchange. However, due to potential security risks like token leakage in the URL fragment, best practices have shifted towards using the more secure Authorization Code Flow even for browser-based applications.
Perfect, got it.
By the way there is any way to have a not expiring token like the standard Token API ?
No, that is the only one which doesn’t change.
