Smartlock 4 pro disconnects from server
My lock is configured for Wifi connection. After 5 minutes connection gets lost to the server. My lock is still pinagble on the local network. MQTT connection is still OK. Network reports RSSI -48 , Wifi Quality 3. Server connection: SSE connecting, Wifi disconnected. Switching internal Wifi off and on and configuring again it stays 5 minutes OK. Running the Beta 4.1.1
My Lock is also freqently disconnecting and wont reconnect without manually reconnecting the WiFi. My current Firmware is 4.0.36. When disconnected, MQTT ist Not Working.
Same probleme here. today I moved the wifi router 2 meters from the lock and the problem did not disappear. the lock disconnects from the server after a while and cannot be accessed. Smart lock pro 4 with beta FW 4.2.0.
This topic is duplicate. For WiFi problems with Smart Lock 4th gen, please use this topic:
