This!
Hope that this release comes fast!
Battery is 74%
Regular status, currently unlocked.
But: I had issues with Bluetooth while retrieving Battery status same as when calibrating (see pic) although in both cases 1m away from the Nuki.
I removed / re-inser the battery and after the restart Bluetooth seems to be ok now same as red led is gone. I will monitor this further.
3.8.4 beta.
This morning Nuki cloud was unreachable and MQTT stopped working.
Not only that, but trying to reconfigure MQTT gave āError 85ā
So I would say this feature is not working
The same with SL4P and 4.2.0 Beta firmware: this morning Nuki cloud was unreachable and MQTT, to a local server, stopped working.
When the cloud was up again, I had to reconfigure the MQTT parameters in order to have it working (no automatic reconnection).
I have success with 3.8.5 in having Nuki again connecto to the router ( GT-AX11000pro ). However I now loose Alexa connection at every wifi change / router reset.
Any idea on that?
Thank you
@Juergen this morning things became worse, both remote actions and MQTT are unusable. Running down a stair is not something recommended, but needed when a smart lock refuse to unlock
is it something investigating? Because I had no answer since I posted about this issue only happening since version 3.8.
I still wonder how you get your SL3P connected to MQTT. I tried for Months now. I have 50+Devices but only the nuki is a problem. I monitored my mqtt-broker, and i get:
New connection from 192.167.13.155:52443 on port 1883.
Client disconnected, not authorised.
Then I configured to allow anonymous logins only for the nuki and now i get:
New client connected from 192.167.13.155:52471 as SL3P_38F91F64 (p2, c1, k300).
Client SL3P_38F91F64 closed its connection.
The nuki doesnt Send a Username!!!⦠but i typed it in (12 simple letters, no special characters.). Support was not helpfull, Firmware reset also. Another Broker doesnt help and another IP-Range (192.168.x.x) also not. I am giving up here. Nuki seems not to be my Doorlock-solution. I will sell the SL3P before i trow it out of the window ![]()
Is 192.167.13.x really your IP range? From my experience the Nuki Lock compares the IP range to an internal whitelist. MQTT Broker and Lock must be in private IP ranges, 192.168.0.0/16, 172.16.0.0/22, or 10.0.0.0/8. If not, credentials are not sent to the broker.
I have had the same issue long time ago because of a Bug with 172.16.0.0/12. But this has been fixed Last year in the Beta firmware.
Yes it is 192.167⦠But this ip-range-problem should be fixedā¦and also it communicates to the MQTT-Broker. I also tried with a small setup with 192.168⦠same here. The nuki doesnt send a mqtt-username although it is enteredā¦
192.167. is not a private network. So the lock will not work with MQTT regardless of the mentioned fix.
In your small setup test with 192.168., both, broker and lock where in the same subnet?
Maybe this helps: I can't connect to my mqtt broker with the Nuki - #3 by Juergen
I donāt know yet what the still red blinking light means.
98% battery, Nuki is calibrated, no error visible, new battery in the Fob, 3.10. firmware. Anything else I can check or you might see in addition @Stefan_Reiterer ?
