Smart Lock Firmware 3.8.x Beta
Smart Lock 3.0 Updates
Smart Lock 3.0 Beta 3.8.0
  • Bugfixes and stability improvements
Smart Lock 3.0 Beta 3.8.1
Dear Stefan,
how can I install a beta version of the firmware (my NUKI smart lock does not work with home assistant via Matt any more (since 2 days)). Maybe the new firmware solve the issues.
Thank you in advance for your reply.
Best regards Walter (Austria)
Sorry, already found the answer!
https://support.nuki.io/hc/en-us/articles/14610613043345-How-do-I-get-the-beta-firmware-for-my-Smart-Lock-#:~:text=First%2C%20you%20need%20to%20find,steps%20required%20on%20your%20part.
Original post has been updated with release notes for the Smart Lock 3.0 Beta 3.8.1
Please install this beta and provide your feedback via this channel - thank you!
MQTT bug with stable version 3.7.7
Up when restart nuki and after 10 minutes connection down on the nuki
On mqtt explorer all messages arrived so it’s a nuki issue
No issues with both 3.8.0 and 3.8.1 found on my side!
MQTT disconnection happens also with this 3.8.1 Beta FW…
See also Inadequate support level (MQTT implementation)
mqtt disconnections happens also to mine at 3.8.1
it’s been happening since 3.7.x , and it’s super important for my usage…
Other 2 things (one good, one bad) about 3.8.1 Beta
  1. the automatic Battery detection type now works (wrt Power Pack of Nuki 3 Pro)
  2. create battery report now doesn’t work anymore (it remains on ā€œcreate reportā€ forever)
Can someone else confirm?
No, but it took a longer time than before to create the report and bring me to the assistant which ask for type of battery to confirm all is find.
Now it takes more than a minute to display next step when it was less than a minute before.
OK… I didn’t wait so long as before it was much faster…
Do you use the iOS or Android App?
I use the Android App.
It takes 75sec in my iOS App to get the battery report. Never tried it before so I canā€˜t compare to earlier than 3.8.1
Before it was few seconds to start
