Second apple watch - problem with missing configuration?
Hello nuki,
i just got my new apple watch 6. i also own an old apple watch 1. On the old watch the nuki app works just fine. On the new 6 modell whenever i start the app, immediately i get (in german, so i don’t know the exact english message) the error message “no nuki found - please open nuki app on iphone and add your first smart lock”. Of course on my iphone the lock is registered with the app and everything works perfectly on the phone itself. I called your customer support, but all i got was “that should work!, do you have latest app and firmware versions?” (which i have) I was left with the comment “We do not give apple product support”. I don’t think, that’s how you treat customers …
So as a last hope, i went to this forum.
This problem usually comes from connection problems somewhere inside the Apple ecosystem. Try to reboot the watch. If this does not help also try to report the phone.
Hi Jürgen,
rebooted both the watch and the phone. That did not fix the problem. Any other ideas?
Do you have the old watch still configured and connected?
You could try to reset it and remove it from the watch app on your phone.
I switched to the watch 6 and set switching mode in the iphone app to manual. Only one watch can be tagged in the app at any time. Is deleting a tested solution or are you guessing? Because i still want to use the old watch too.
I mean, the new watch does not even try to connect. It pops the above mentioned error message the second you open the nuki app on the watch. The app either got no configuration at all from the nuki app on the phone or can’t connect to the nuki app on the iphone. I granted all kinds of rights (bluetooth, GPS, etc.) to the nuki app on the phone and on the watch. I wasted a whole afternoon and evening on the problem so far and still got nowhere. Every other comparable app works, HUE and homematic apps have no trouble at all.
I have the exact same issue. I made a factory reset on the old phone. Also removed the app, rebooted and reinstalled on the new watch. It still responds the Nuki is not found. Any other suggestions?
Same problem i have. Rebooted Phone and Watch, reinstalled Nuki ON Watch, still no Nuki found
Edit: removed Nuki Watch app, rebooted Both Watch and Phone, waited 5 minutes, reinstalled Watch app and worked :+1:
Thanks Silviu! :pray:
Hi everyone - I face the same issue with my new Apple watch. I never had an old one connected so no need of deleting anything upfront.
I followed the suggestions to uninstall, reboot, reinstall etc but still “kein Nuki gefunden”. No other app has similar problems… Any new insights from the experts?
I have the same issue since I have a nuki lock, and wanted also solve it here, but got a short answer from nuki, you will get no answer, because the function works and has no problems!?
I have the same issue and have tried all of the above but still get the same error message.
Would be very unfortunate if Nuki just do not care.
Same issue with new Apple Watch 7.
I thought it was because I have beta versions of iOS and watchOs but it seems that this is not the reason…
update: I killed/relaunched several times the application on the Apple Watch, and now it is working…
I have the same problem, I have reinstalled/rebooted several times
Lock: Nuki 3.0 Pro
Apple Wacht 6
Iphone 12
As i was typing this … it started working.
Maybe that’s the trick :smiley:
Had the same problem with my new series 7 after restore from back from the series 6.
After a reboot it worked!
Dame here. New iPhone 13. Had to reconnect to my existing watch. Only app didn’t make te cut was Nuki. Asking to open iPhone, etcétera. Did Uninstall and reboot. Not working.
Thank you!!!
Hi, I configured a new AW 8 and I am having exactly the same problem as described (in German, too). I rebooted everything, reconnected, deleted the first watch I have… Nothing helps! I am starting the AW App and I am getting the message that “No Nuki is found”… Any additional hints?
2023, the problem is still there.
I sold my old Apple Watch (unpaired).
Unboxed the new one, installed the Nuki app.
App said “no Nuki lock found”.
Repeatedly deleted and uninstalled the app.
Helped up:
  • delete the app in AW
  • turn off AW
  • turn off iPhone
  • turn AW on
  • turn on iPhone
  • install the Nuki app
  • wait about 3min with the app open.
