Nuki Pro Mk4
As I understand the “Opener” it can be authorized to open the lock via bluetooth when the “ring” circuit is closed (yellow wire to ground).
But maybe I do not understand at all.
Does the “ring” circuit open the Nuki lock, or simply activate the “open” relay… Pre-purchase Question Nuki Opener: Wiring with simple relay (doorbell) and switch (opener) setup
My video phone has 2 outputs at the camera module at the front door.
1 - open the door (12V for latch release}
2 - open gate (switch closure for gate motor control)
I don’t have a latch release. The door auto locks to the frame as it is closed, and then the Nuki lock turns the key to make it secure.
I would like to be able to open the Nuki Lock (turn the key) with one of those outputs from the videophone… keeping it simple and secure for everyone.
Thank you in advance,
David.
