If it never worked for you please try to disable and enable them again in the opener administration.
If that doesn’t help please send a log-file o our support team at contact@nuki.io, so they can try to check for the reason of the problem.
Ok it works… a little bit.
But I do not understand why I am logged out of the app after an indefinite period of time and I am informed that the session has expired.
I think this could be a reasen for not delivered push-messages. Maybe you have always to be logged in at the app to nuki web for messages?
No. You are only logged out if the token gets invalid (time period; other sessions deacitvating concurrent ones etc.)
The log-in is only used to connect your App to a Nuki Web account for a specific device, as the Nuki Web log for the device is used to trigger the push notifications.
So if you can see activity log entries in Nuki Web they should also create a push notification to your App without further delay (according to your settings). No need to check if you are still logged into that account in the Nuki App.
Yes, because for Ring to Open where are separate push messages (via lock actions) used as the ringing will already have opened the door when you receivce the notification.
O.k., this then means that your Bridge has some issue with automatically syncing an updated status. Could you send me a PM with your device IDs there I can follow up with some more detailed questions?
@MatthiasK Are you already making progress on improving the notification delay? This feature was one of the main reasons for me to get the Opener but it only makes sense if the delay stays below ~2 seconds.
On a related note, there is also a significantly longer delay when unlocking with the Opener vs. unlocking with the Smart Lock (using Google Assistant). Adding everything together (delayed notification, delayed Opener unlock), visitors are long gone before being able to open the doors for them.
@nukor What delay times do you experience? And do you have Smart Lock and Opener on the same bridge?
@Michiel The delay should not be 20+ seconds. Do you see the same dely in updates to Nuki Web or only for the notificiatons on your smartphone?
@shidemo Please send a log-file with a short description of the problem and the exact time when it occured to our support team at contact@nuki.io, so they can check the details of what happend.
@MatthiasK, both web en smartphone have show same delay. The weird thing is that I just tried it twice within 5 minutes and the first time it took over 20 seconds and the 2nd time around 5 seconds on both web and smartphone. to receive the notification.
@Michiel O.k., if it’s the same in Nuki Web then it the delay is most likely from the Bridge. Do you have any integrations running on the Bridge API? Other reasons could be HomeKit or devices connected to the Smart Lock via bluetooth while status updates are being pulled by the bridge.
+1 …Very long time to take notifications!
initially I did not receive any notification (I opened an issue yesterday but I have not yet received an answer), finally, hidden in the sub-menus, I found the item smartnotification (absurd complexity to activate it and check if some parameters disable them).
Notification times are totally variable but above all UNACCEPTABLE, from a minimum of 20s to more than a minute !!!
If I found a way to capture api messages (they rang, nuki opened) I would try to solve with other instruments (iobroker).
At the moment I am embittered, I come from a previous solution Nello (now failed) which provided notification times of not even 1s!
Maybe you have problems due to the Covid quarantine, however email responses are also taking a long time like the notifications of the opener.
I repeat that the app’s notifications to the intercom sound are truly unacceptable, please do something or tell me what to do.
You should not experience such a long delay. Have you already tried to contact our customer care to go through your setup/connection quality etc. to check if everything is fine? (https://nuki.io/en/support-request/)
Hi Stephan, I don’t really know what kind of problem there may be. Notification times are very variable, really too much.
Sometimes it comes after 3-4s other times after 10-15s, sometimes it just doesn’t come.
I tried to intercept the change of state of the “dateUpdated” field through an ioBroker plugin, I checked the state of the “state” in the WebApi, but that’s not what I want.
It would be helpful to have a WebApi service field indicating “someone ringing” status.
But above all it would be useful for the app to provide me with the notification in a couple of seconds and in a stable way, allowing me to open from the Apple Watch or from the phone.
Now if I’m at home and I hear the intercom ringing I don’t know how long the notification will come to me, so I go to the intercom … sometimes it comes while I pick up the receiver other times when the second entrance rings … sometimes after a few minutes …
The internet connection is good (200mbs) and stable, previously I used nello.io (I think you knows it), and then the notifications were almost immediate.
Same network, same wifi.
I send a request to Nuki support and this is what they said: Please go to the “Manage notifications” section of the Opener (menu - “Manage my devices” - “Opener” - “Manage Opener”) and deactivate all notifications. After that leave the section, re-enter it and activate all the notifications you want to recieve.
Done…no result, I told them…but no answer at all…
Who can I contact?
PS
it will be useful to have an MQTT service for the ringing state…
