j’ai fais la demande à Nuki pour la comptabilité de l’Opener avec plusieurs interphone
Mais j’ai pas de retour de leur part, es ce que l’on sait si c’est compatible avec le poste interphone Aiphone GT1D ?
Pouvez vous nous dire comment cela se branche sur un interphone à Bus 2 fils ?
merci pour vos commentaires
Xavier
I will try to answer your answer I just auto-translated. ![]()
The current state of compatibility to intercoms can be found at Opener | Nuki The Smart Lock (or https://nuki.io/fr/opener/). If your model is not listed there you can still submit a request so we can see that there is demand for that model and check compatibility (based on that demand).
Especially with BUS intercoms it is hard to give general statements without doing some research and you have to understand that there is broad demand for different models at the moment.
Hi Stephan,
Do you have any update on this ?
I tried to connect it as mentioned in the https://developer.nuki.io/uploads/short-url/3naDfQDFbzh3Je7ytrNzRDscvFz.PDM
It recognizes the signals when I push on the doorbell. Or on the door unlock button during the calibrations. But the Nuki can not unlock the lock.
I expect that the reason for this is:
The phone first need to be activated by someone who pushes the bell.
And than the phone horn needs to be removed before you can open the door with unlock button.
Do you have any idea how to resolve this ? ( I am waiting already 5months for a reply from Nuki )
my post: Nuki opener with Aiphone GT-1D
Hi Yannick,
there is an alternative installation flow ( for intercom systems that need activation) you can enter after retrying the Ring to Open test at the end of the setup routine. Did you try it?
yeah, I tried it.
but the door never opened
Hi Georg,
In the Beginning of this year I installed the door opener. But I still didn’t manage to get it working as I mentioned before ( Using the alternative installation with intercom activation )
I have more and more people contacting me who have the same questions/problems as me.
Could you guys please look into this ?
Thanks in advance
Im also waiting for the correct wat to install the opener with the Aiphone gt-1d.
Really hope someone can come up with a solution.
mvg Mike
Same here, I have Aiphone GF-1D
Blanco, as-tu réussi à connecter ton GT1D à Nuki Opener ? J’ai le même et rencontre les mêmes difficultés
Just to add a level of demand for this compatibility.
I live in an Apartment complex that just installed 713 of the AIPhone GT-1D model.
The complex is 60% Investor/Owners renting out as Short Term Rentals via AirBNB and others. All of whom would love to come up with a keyless check-in method for guests. From letting them in the Apartment Building Door(s), to letting them into the apartments directly.
So a working solution here would easily be eaten up. With the upsell opportunity of the compatible door locks. Does that help with increasing priority?
Regards, Kieran
Apparently not…
Same issue I have an Aiphone GT-1A and no tutorial available, that’s annoying to replace the whole system.
Does anyone have an update regarding the installation ?
Thank you in advance,
Victor,
Bonjour à tous (et aussi @dev )
J’ai le même problème avec cet interphone. Pas de nouveau ?
Si vous envisagez d’acheter un nouvel interphone ou si vous avez déja fait le remplacement, quel modèle avez-vous choisi et est-ce que l’installation a été facile ?
Merci de votre aide !
Same situation here. I wish Nuki could find a solution for GT-1D owners… We are quite a numbers now who are asking for this support.
thanks !
What’s the latest on the GT1A and GT1D compatibility development?
The manufacturer Aiphone dominates the market for new installations in our seaside town.
Thank you for your feedback.
Best regards, Thomas
