Hey,
I am now a proud owner of a Nuki Ultra. Everything works pretty smoothly, but the integration via Matter does not work. I made sure that the smart lock, the Echo Show 10 3rd generation and the Nuki and Alexa apps have the newest firmware. I restarted all devices including the router, everything is connected with 2.4 GHz.
Still, every time I try to connect via Matter, I see this error message saying: “Something went wrong.
Make sure that you’re connected to your network and try again”
Just a few days ago I successfully connected my Nuki Ultra to Alexa via Matter using the Echo Show 15 (2nd gen). It took a few attempts, but I eventually got it working.
If I’m not mistaken, this screenshot looks like from Google Home and not the Alexa app.
Does this screen appear if you scan the Matter QR Code with the Alexa app?
No, when I start pairing in the Nuki app. It asks me which app to use. Then I switch from Google to Alexa. Then this screen appears after some seconds where it tries to connect (see screenshot).
If this screen is appearing, please ignore it as this is from Google Home and will try to start Matter commissioning with Google Home instead of Alexa:
You have to activate Matter Pairing via Nuki App first but from your previous messages it sounded like you anyhow did that.
The full LED ring of the SL should be lighting up while it waits for someone to pair via Matter.
During pairing (as soon as the ecosystem connects and starts the pairing) the upper LED segment should blink.
If the screen inside the Nuki App shows you an already existing but not working Matter connection, please click “Disconnect Matter” first an then activate it again.
Yes, that’s exactly the kind of LED pattern that shows up (first full ring lights up, then the upper segment flashes). But then the error message appears.
Connecting your Nuki to an Amazon Echo via Matter won’t enable remote control, such as locking or unlocking. The technical hurdle is that Matter uses IPv6, but Nuki’s servers are IPv4-only. Unless your Thread border router supports NAT64 (which Amazon Echos do not), the necessary communication cannot occur.
Without NAT64 the Thread connection provided by Matter won’t allow the Nuki Apps to remotely control the Smart Lock. So you would still need to use WiFi if you want to use that.
But this has nothing to do with whether or not you’ll be able to use Matter in general and also using Matter to remotely lock or unlock the door.
So also without NAT64 you’re able to connect your Smart Lock to Matter and remotely control it via Matter.
