Hi all,
It’s from yesterday that when I sent MQTT messages through Home Assistant, the Nuki Pro 4.0 doesn’t do anything. I can’t open or close the Nuki from Home Assistant.
Home Assistant can easily read the MQTT messages that the Nuki sends. Nuki Version Firmware 4.1.8
Here some logs:
2024-02-20 22:35:12.315 DEBUG (MainThread) [homeassistant.components.mqtt.client] Received message on nuki/[NUKI_CORRISPONDING_ID]/connected (qos=0): b'true'
2024-02-20 22:35:13.034 DEBUG (MainThread) [homeassistant.components.mqtt.client] Received message on nuki/[NUKI_CORRISPONDING_ID]/batteryChargeState (qos=0): b'67'
2024-02-20 22:35:13.037 DEBUG (MainThread) [homeassistant.components.mqtt.client] Received message on nuki/[NUKI_CORRISPONDING_ID]/batteryCritical (qos=0): b'false'
2024-02-20 22:35:13.038 DEBUG (MainThread) [homeassistant.components.mqtt.client] Received message on nuki/[NUKI_CORRISPONDING_ID]/batteryCharging (qos=0): b'false'
2024-02-20 22:35:13.039 DEBUG (MainThread) [homeassistant.components.mqtt.client] Received message on nuki/[NUKI_CORRISPONDING_ID]/state (qos=0): b'1'
2024-02-20 22:35:13.039 DEBUG (MainThread) [homeassistant.components.mqtt.models] Rendering incoming payload '1' with variables {'entity_id': 'lock.stock', 'name': '', 'this': <template TemplateStateFromEntityId(lock.stock)>} and Template<template=({% if value in ("5","6","7") %}3{% else %}{{value}}{% endif %}) renders=6>
2024-02-20 22:35:45.885 DEBUG (MainThread) [homeassistant.components.mqtt.client] Transmitting message on nuki/[NUKI_CORRISPONDING_ID]/lockAction: '1', mid: 49, qos: 0
2024-02-20 22:36:01.471 DEBUG (MainThread) [homeassistant.components.mqtt.client] Transmitting message on nuki/[NUKI_CORRISPONDING_ID]/lockAction: '3', mid: 50, qos: 0
2024-02-20 22:36:02.929 DEBUG (MainThread) [homeassistant.components.mqtt.client] Transmitting message on nuki/[NUKI_CORRISPONDING_ID]/lockAction: '3', mid: 51, qos: 0
2024-02-20 22:36:03.109 DEBUG (MainThread) [homeassistant.components.mqtt.client] Transmitting message on nuki/[NUKI_CORRISPONDING_ID]/lockAction: '3', mid: 52, qos: 0
2024-02-20 22:36:03.469 DEBUG (MainThread) [homeassistant.components.mqtt.client] Transmitting message on nuki/[NUKI_CORRISPONDING_ID]/lockAction: '2', mid: 53, qos: 0
2024-02-20 22:36:04.641 DEBUG (MainThread) [homeassistant.components.mqtt.client] Transmitting message on nuki/[NUKI_CORRISPONDING_ID]/lockAction: '3', mid: 54, qos: 0
2024-02-20 22:36:04.819 DEBUG (MainThread) [homeassistant.components.mqtt.client] Transmitting message on nuki/[NUKI_CORRISPONDING_ID]/lockAction: '3', mid: 55, qos: 0
2024-02-20 22:36:05.009 DEBUG (MainThread) [homeassistant.components.mqtt.client] Transmitting message on nuki/[NUKI_CORRISPONDING_ID]/lockAction: '3', mid: 56, qos: 0
