Hello, I tried to install Nuki Opener in my apartment, but I have the following problems. I have an intercom from Comelit 2738W and can’t find instructions in the Nuki app for Comelit 22738W. I ask for help and information on how to install Nuki Opener on my intercom system (see photo). How should I connect the cables? Thanks a lot!!
Please answer, I need your help! Thanks!
It looks like company don’t want to respond to your request Aleksandr. I am frustrated about Nuki opener as well because I have almost the same model of Comelit and can’t find a help. Will return this product back, and don’t recommend to anyone.,. Unfortunately
Hi Aleksandar, hi Vadim,
sorry, but we are currently not compatible with the bus-based systems from Comelit.
Best regards
Georg
Is it expected to be compatible in near future? When could be compatible?
Hello, any update with Comelit 2738W/A ?
any news?
eric
did you try this;? It’s not the same intercom, but the method is interesting."
any news about 2738?
I am in the same situation. I’d like to install the opener for the Comelit 2738W intercom but I cannot find any documentation. Please reach out to me if you have found a solution.
Have you tried to set up the opener on your 2738W intercom using the documentation of the 2708W model? Was it working?
Bests
Alexandra
Hi, did anyone solve the problem with Comelit 2738W?
My configuration works but it doesn’t register it inside the Nuki app. How can I solve the problem?
