Nuki Opener | Golmar T-940 Plus
Mine is still not working, today I tried a few more things:
Once i’ve wired up as per the diagram, if I test the intercom before attaching Nuki physically to the other end of the cabling, the intercom works perfectly.
BUT as soon as I attach the Nuki Opener to the cabling, the whole intercom stops working - in configuration mode or not. The intercom both upstairs and downstairs simply makes an error beeping noise when you try to use it.
So i’ve established that it’s not my wiring up that’s causing the issue, but when the Nuki is attached the intercom stops working altogether. I’m guessing this isn’t expected behaviour.
Hello Georg,
I can’t create a feature request, i want also request support for uno devices.
Nuki Opener
Know that the Golmar Plus are supported, we want also the UNO devices supported. Many apartments and offices are installed with Golmar UNO devices.
Support for Golmar T-740 Uno intercom.
Many apartments and offices are installed with Golmar UNO devices in the EU.
See the Golmar Plus devices support.
Please for vote UNO support here:
Good to hear that you’ve successfully wired it up. Can you confirm whether your wires are similar to mine?
Just voted.
Any news about this? Can we install the Opener on a T-740/T-940 Golmar Platea device? It doesn’t matter if it’s unofficial, but I want to know if this set can currently work
Hi, any news on this?
My neighbours and I have the platea uno and we are all waiting for the solution to buy the kit.
Thank you.
I lost all my hope but @Juergen can you please show us some light in here? it’s been years now… :frowning:
The only way to support Nuki Opener and Golmar T-740 UNO is to solder 2 points on the board at the “open” button - then connecting the blue/purple cable of the Nuki to them, causing a loop when pressed. This will open the door downstairs, but only if the bell is ringing.
So for me personally, when I arrive at my appartment I can now ring my own bell and press open in the Nuki app to open te door. Or somebody can call my mobile and I can open it remotely if they ring the bell.
So in essence - the basics are now working.
I wish to know now if we can somehow detect the ring (HZ-) and have Nuki trigger the open automatically.
