I have recently installed my nuki smart lock pro 4th gen, and i have face several issues, first my nuki goes dead after 3days…thought that battery has drained out, because a simple unplug/plug doesn’t work… I charge de pack roughly 1h plug it back, and for my surprise it almost fully charged 96%, i have set the energy mode to automatic and im running fw 4. 3.10.
Also its impossible to generate a battery report… Simply impossible ->Failed to get device information:unable to connect to the device.
Im really disapointing with this SL so far, any ideas here?
Hi @Ivo_Costa ,
I’m really sorry to read about your bad experiences you made with your Smart Lock so far.
Apparently we found a critical bug recently, which might have caused the mentioned troubles. Luckily, this fix was released today as hotfix version 4.3.11, thus I’m kindly asking you to upgrade your device to this version and let me know if it’s working then as expected.
Additionally please try to charge the power pack overnight, as the general charging duration is defined with up to 10 hours.
You can also reach out to me via DM if you have more specific questions.
Thanks and best regards
Stefan
Thanks for the hint to the new firmware, I upgraded immediately from 4.3.10 to 4.3.11.
But the creation of the battery report still fails: “Failed to get device information:unable to connect to the device”
When trying it, the distance between mobile phone and smart lock was less than 2m.
Appreciate your help,
Nick
Yes, the battery report has never worked for me on SL4. I’ve just tried it again on firmware 4.4.1, it always says it can’t connect to the lock.
Thanks, i have updated let give it couple of days to see if there is improvements.
Ok, i thought that was just me… But in that case i will wait for it to be available
hello @Stefan_Reiterer , i have made the update 2w ago, and seems better but battery doesn’t hold more than 10days now… it goes completly dead, and im not sure if the battery pack has an issue or is indeed the nuki that has an high level comsumption, without the battery report is difficult to understand what causes this…but 2w is far from the “lets you experience a battery life of up to 6 months.” can you please advice here ?
I’m having the same issue. Software is always up to date. Battery barely makes it 3 days. Bought the device back in September last year, but after the first three months the performance has been very troublesome. Even replaced the battery pack. No improvement. It’s also quite random. Despite a consistent routine and usage, have never been able to get a battery report generated, and sometimes it lasts 3 days, sometimes 9, but not once has it lasted more than a month. I’ve set all the settings to battery saving too.
I am also facing the same issue. The battery barely lasts 3 days with minimal usage.
The lock goes offline very often and the wifi connectivity is also very flakey.
I am extremely disappointed.
I don’t think that the firmware hot fix worked at all because even after update, I do not see any improvement at all.
Ok, so i have made some experimentas to try to understand why sometimes battery hold for 2w and sometimes 2 days and here is what i found:
1- Im convinced that isnt the battery pack the issue.
2- Definitly if SL4 for a unknown reason lost connection to the wifi( independent of the reason) it drains the battery in 1/2 days trying to connect to the wifi, even if there is no wifi issue with your network.
3- Once SL4 is in this state, the only way te be able to reconnect to the wifi is by disabling the wifi in the nuki app, and enable it again, than SL4 reconnect again with no problem.
@Juergen @Stefan_Reiterer Any ideas? Can you folks have a look to my SL4 logs to get more insight of the issue?
I’m having the exact same issues as the guys above
Did anyone find a solution for this??
Hey everyone - just an fyi I did the latest firmware update (4.5.5) Which included improved WiFi module stability. That was just over a week ago and touch wood I haven’t had an issue since which is a PB for my lock
I am also having these issues (smart lock 4th gen) it all worked fine for around 6 weeks then (after an update I think) started to get the random battery drain and wifi not reliable.
Been talking with customer services and sending screenshots of battery data etc , last thing i tried was turning wifi off , it seemed better so they are in the process of sending me the bridge but last night I came home and the battery was critical again.
Also thought I had an issue with the lock n go but it turns out you cant use lock n go and the door sensor as the sensor overrides it , it tries to lock after it sees the door is closes .
Starting to wish I bought a Yale …
Yeah despite me saying the the update fixed it - it didn’t. It started going it again. I’ve been back and forth with nuki, having to do loads of trouble shooting. At the minute I’ve set up the router to have a guest network with only the Nuki on it, and have the WiFi on compatibility mode and it’s definitely better. Hasn’t dropped off for a while.
Although I have another issue as well and it’s getting replaced under warranty, so it so be interesting to see if the new one has the same problem. It does seem to be the smart lock pro 4th gen that has this problem.
I set mine up on a guest network with compatibility mode , my network app is showing the nuki connected but the lock is showing no connection (randomly) , I am using a BT router with BT whole home discs , what router are you using , if you don’t mind me asking ?
Mine is a TP Link router, combined with a 4g SIM for WiFi connection rather than wired in. Works great with everything else.
The last two firmware updates have had “improved WiFi module stability” as part of the update so I think Nuki must know they have an issue
Yes , I installed a ring doorbell on the same network and its worked flawlessly , I hope nuki can sort it as its a great lock , if it worked !! …
