Please find release notes for all our future releases in our support documents: https://support.nuki.io/hc/en-us/sections/12387599851281-What-s-new .
This is an overview of the past Nuki Android App public releases.
Android App 2022.12.1
(19.12.2022)
Bugfixes:
- Performance improvements and bug fixes
Android App 2022.11.2
(23.11.2022)
Bugfixes:
- Fixed issue for Nuki Opener “Continues mode”
- Fixed issue where the created invitation code was cropped on certain devices
- Fixed issue where icons where not shown for widget
- Fixed issue during fingerprint enrollment when animations where disabled (when certain accessibility settings are activated)
Android App 2022.11.1
(14.11.2022)
Features:
- Support for the new Nuki Keypad 2.0: With the Nuki Keypad 2.0 you can open your front door via fingerprint or with an entry code.
Android App 2022.10.1
(19.10.2022)
Features:
- Activate Nuki Smart Hosting directly via the Nuki app and benefit from numerous advantages when renting out your holiday property.
- Further usability improvements: The “Features & Configuration” area has been clearly grouped and a new search bar has been introduced.
Android App 2022.9.1
(07.09.2022)
Features:
Android App 2022.8.1
(17.08.2022)
Features:
- New display of permissions - in the device settings the permissions are now divided by User, Keypad and Fob
Android App 2022.7.1
(06.07.2022)
Features:
- Reworked Settings screen with new grouping and design
- Manage all features and device settings via “Features and Configuration" in your Nuki app.
Android App 2022.5.1
(04.05.2022)
Features:
Android App 2022.4.1
(06.04.2022)
Features:
- Improved WearOS app: You can now control your Nuki device faster and easier.
- User-friendly setup: Improvements for the initial setup of the Nuki Opener
Android App 2022.3.1
(02.03.2022)
With this release we changed the versioning scheme. From now on all apps and wearables will versioned like this: <YYYY>.<M>.<RELEASE_NR>, where <YYYY> corresponds to the release year (2022), <M> the month of release (3), and <RELEASE_NR> the increasing release number in the given month (1).
Features:
Android App 3.1.0
(03.02.2022)
Features:
- Auto Unlock improvements
Android App 3.0.4
(16.12.11.2021)
Features:
Android App 3.0.3
(15.12.11.2021)
Features:
Android App 3.0.2
(29.11.2021)
Features:
Android App 3.0.1
(17.11.2021)
Features:
Android App 3.0.0
(4.11.2021)
Features:
- Support for our new Nuki Smart Lock 3.0
- Support for our new Nuki Door Sensor
- Support for the new Smart Door KFV
- We now also support the lift-up handle
Android App 2.11.1
(21.10.2021)
Android App 2.10.1
(16.09.2021)
Android App 2.10.0
(02.09.2021)
Android App 2.9.0
(05.08.2021)
- Secure and easy Nuki Web login: Benefit from even higher security standards with the new login to your Nuki Web account.
- Amazon Alexa & Nuki: Now you can connect Nuki and Amazon Alexa directly in your Nuki app and control your Nuki devices via voice control.
- Your security and privacy are our priority! We provide detailed security and privacy information in the Nuki app.
Android App 2.8.0
(08.07.2021)
- Add exclusive Nuki service packages to your Nuki device directly via the Nuki app.
- Huawei Watch support: With the new Nuki Huawei HarmonyOS Watch App you can now open your door from your wrist!
Android App 2.7.7
(10.03.2021)
- Performance improvements and bug fixes.
Android App 2.7.6
(15.03.2021)
Features:
- Galaxy Watch support (Beta): With the new Nuki Galaxy Watch App (Beta version) you can now open your door from your wrist!
- Direct locking actions are not possible with the Nuki Galaxy Watch App (Beta).
- Locking actions are sent from the watch to your Nuki Smart Lock via the connected smartphone.
- The watch offers the same locking actions that are visible in the Nuki smartphone app by simply tapping on the respective door lock.
- The Galaxy Watch App is a Companion App, so you need to have the Nuki App installed on your smartphone to use the Nuki Galaxy Watch App.
- Requires Nuki Android App version ≥ 2.7.6.
- New security setting: Receive a warning if you select “Open door” and are not near your door.
Android App 2.7.5
(08.02.2021)
Features:
- Garmin Watch support (Beta): With the new Nuki Garmin Watch App (Beta version) you can now open your door from your wrist! NOTE: If locking via the Watch does not work right away, you have to delete your Nuki device from the app and add it again.
- You can now create support tickets in the Help section.
Bugfixes:
- several bugfixes and performance improvements (also including the Smart Door)
Android App 2.7.4
(16.12.2020)
Features:
- Improved Smart Lock factory reset - now it is possible to restore the default settings while keeping your user data (requires Smart Lock firmware ≥ 1.10.3, or Smart Lock 2.0 firmware ≥ 2.8.15).
- Improved help section
Bugfixes:
- Several bugfixes and performance improvements (also including the Smart Door)
Android App 2.7.2
(25.11.2020)
- Improved support for Huawei phones
Android App 2.7.1
(9.11.2020)
- Improved Smart Lock setup flow for business customers
- Now it is possible to enabling automatic firmware updates for the Smart Lock and Opener (requires Smart Lock firmware ≥ 1.10.3, or Smart Lock 2.0 firmware ≥ 2.8.15, or Opener firmware ≥ 1.5.3)
- New Keypad battery warning (requires Smart Lock firmware ≥ 1.10.3, or Smart Lock 2.0 firmware ≥ 2.8.15, or Opener firmware ≥ 1.5.3, and Keypad firmware ≥ 1.7.0)
- The Nuki app is now also available in Polish language.
- New: enable authentication to keep the access to the Nuki app secure
Android App 2.7.0
(1.10.2020)
- Improved Smart Lock setup flow.
- NEW: Smart Door. With this update you can manage the brand new Smart Door in the Nuki app.
- Show battery status in percent (requires Smart Lock firmware 1.10.0 and newer or Smart Lock 2.0 firmware 2.8.1 and newer).
Android App 2.6.10
(7.8.2020)
- Improved firmware update for Opener
Android App 2.6.9
(2.7.2020)
- Improved firmware update for Nuki Smart Lock
Android App 2.6.8
(3.6.2020)
Android App 2.6.7
(6.5.2020)
- Fixes a bug with the firmware update on Smart Lock 1.0
Android App 2.6.6
(3.4.2020)
Android App 2.6.5
(4.3.2020)
- Additional Auto Lock settings (available with Smart Lock 2.0 from Firmware 2.7.8)
Android App 2.6.4
(5.2.2020)
- Display battery level in battery settings screen
Android App 2.6.x
- Compatibility enhancements with Android 10
Android App 2.6.1
(17.12.2019)
- Increased Opener compatibility
Android App 2.5.x
Android App 2.5.1
(7.11.2019)
- Widget support
- App shortcut support
- Additional option for Night mode
Android App 2.5.0
(29.10.2019)
- NEW: Night mode. During the selected period, the energy saving mode of the Smart Lock is activated and the door is locked twice. Controls Auto Lock and Auto Unlock actions.
Activate it in the device settings > Manage Smart Lock > Night mode.
(available with Smart Lock 1.0 from Firmware 1.8.0 and Smart Lock 2.0 from Firmware 2.6.2) - Battery Warnings on Main Screen and Bottom Sheet
- Improvements for the Opener setup
Android App 2.4.x
- Improvements for Auto Unlock and the Opener
Android App 2.4.0
(10.9.2019)
- Android 10 compatibility
Android App 2.3.x
Android App 2.3.0
(31.7.2019)
- NEW: Push notifications. Nuki can send you notifications when activities are being performed with your electronic door lock, or when there are important warnings. Activate it in the device settings > Manage Smart Lock > Manage notifications.
Android App 2.2.x
Android App 2.2.0
(21.6.2019)
- Support for the new Nuki Opener.
- In order to make the Nuki app even easier for you to use, we have redesigned the app menu and the device management.
Android App 2.1.7-2.1.8
• Performance improvements and bug fixes.
Android App 2.1.6
(14.5.2019)
• Auto Unlock improvements, especially for Samsung devices.
Android App 2.1.5
(10.4.2019)
- NEW: In the Auto Unlock expert settings the speed of the Auto Unlock feature can now be reduced so that doors are not opened too early.
- From now on, all error messages in the Nuki app will show additional error codes, so that the Nuki support team can identify problems more easily.
Android App 2.1.4
(7.2.2019)
- We improved the Auto Unlock feature. Delayed Auto Unlocks are even better detected and intercepted, so the door won’t open when you’re already inside.
- The battery consumption of the Nuki app has been optimized.
- Further performance improvements and minor bug fixes.
Android App 2.1.1-2.1.3
Android App 2.1.0
(18.12.2018)
- From now on when you tap on your Smart Lock, you will see the suggested locking actions. With a swipe gesture upwards you can see further actions. With a swipe downwards it all disappears.
- The main view and controls of the Nuki app have been optimized for use with VoiceOver.
- Auto Unlock improvements.
- Various bug fixes.
Android App 2.0.x
Android App 2.0.0
(5.11.2018)
- Support for our new Nuki Smart Lock 2.0.
- Support for our new Nuki Keypad.
- Fixes a bug in the Nuki Box subscription management.
