Hello,
Attached my feedback about the Nuki firmware 2.3.11 and my issues before.
- Lock & Go:
Now works as expected. - Time control:
Basically works as expected, but sometimes the Nuki tries to lock although it was already locked (clutch engages).
The following issues persist:
- User info:
Last access and the number of lock operations are not logged (iOS-App 2.0.4 [1077]) - Clutch:
The clutch opens very quickly while the gearbox is still running down. Is this behavior so desired? - Battery Warning:
When pulling the latch there is a battery warning. Only with the Nuki 2.0. With the Nuki 1 and the same batteries there is no warning. Batteries are only one week in use. Attached information about the use of batteries (Zuhaus: Nuki 1, Zuhaus 2: Nuki 2.0). - Temperature:
Displayed or measured temperature too high. See Screenhots between Nuki 1 and Nuki 2.0. - Missing
Nuki 2.0: Signal strength based “nearby fence” (My “Issue” with Auto Unlock)
Greetings
Frank
