No Webhook State after LockAction Nuki 2.0
After LockAction my FHEM Nuki 2.0 Device becomes no state from Webhook. With Nuki 1.0 comes the state within 10s from webhook.
Are there any differences in communication with the bridge between Nuki 1.0 and Nuki 2.0?
Ich kann übrigens besser Deutsch wie Englisch :wink:
Grüße
Leon
Happens to me as well. No Callback (after an lockAction-Call) for the new LOCKED-State. I looked in the Bridge-Log and there is no HTTP-POST-Entry for the Callback :frowning:
For an Unlock-Action-Call I get an Callback with the new UNLOCKED-State. There is an HTTP-POST-Entry in the Bridge-Logs.
Grüße.
niklas
Yes, there seem to be some issues with lockAction-calls from the HTTP-API not triggering the Callback correctly for Smart Lock 2.0. We are locking into it.
Thanks again for the details from your log-files via PM. The problem seems not to be connected to a certain action or state, but we need to investigate deeper.
No. This should be the same.
But atm we only noticed the described problems for v.2
I would like to emphasize again that I use the Bridge API. The bridge does not send me any status via the webhook!
The Bridge API is the HTTP API.
So do you get no callbacks at all? Or only none after lockActions from the API?
Generally, I do not get CallBacks through the Bridge API, no matter if I switch to HomeKit, FHEM or the Nuki App.
HomeKit gets the status but signaled, there it is always correct.
could you have a look in the bridgelog and search for the term HTTP-POST? You can access the bridgelog with http://< bridge-ip >:8080/log?token=< your api-token >
No HTTP-POST in the logfile
Here is the log from the bridge when I have the Nuki app locked.
timestamp: 	2018-11-14T08:22:32+00:00	 	type: 	HTTP-Log
timestamp: 	2018-11-14T08:22:32+00:00	 	type: 	WLAN-SocketConnected	 	connection: 	0
timestamp: 	2018-11-14T08:22:09+00:00	 	type: 	HTTP-PostFailed	 	urlId: 	0
timestamp: 	2018-11-14T08:22:08+00:00	 	type: 	WLAN-SocketDisconnected	 	 connection: 	3
timestamp: 	2018-11-14T08:22:05+00:00	 	type: 	WLAN-SocketDisconnected	 	connection: 	0
timestamp: 	2018-11-14T08:22:05+00:00	 	type: 	WLAN-SocketConnected	 	connection: 	0
timestamp: 	2018-11-14T08:22:04+00:00	 	type: 	WLAN-SocketDisconnected	 	connection: 	0
timestamp: 	2018-11-14T08:22:04+00:00	 	type: 	WLAN-SocketConnected	 	connection: 	0
timestamp: 	2018-11-14T08:21:55+00:00	 	type: 	WLAN-SocketDisconnected	 	connection: 	0
timestamp: 	2018-11-14T08:21:55+00:00	 	type: 	WLAN-SocketConnected	 	connection: 	0
timestamp: 	2018-11-14T08:21:54+00:00	 	type: 	HTTP-Post	 	urlId: 	0	 	nukiId: 	XXXXXXXX
timestamp: 	2018-11-14T08:21:52+00:00	 	type: 	WLAN-SocketConnected	 	connection: 	3
timestamp: 	2018-11-14T08:21:51+00:00	 	type: 	HTTP-PostStart
timestamp: 	2018-11-14T08:21:51+00:00	 	type: 	BLE-Disconnected	 	nukiId: 	XXXXXXXX
timestamp: 	2018-11-14T08:21:51+00:00	 	type: 	BLE-Disconnect	 	nukiId: 	XXXXXXXX
timestamp: 	2018-11-14T08:21:50+00:00	 	type: 	SSE-KeyturnerEventReq	 	nukiId: 	XXXXXXXX
timestamp: 	2018-11-14T08:21:50+00:00	 	type: 	BLE-ReceivingMsg	 	nukiId: 	XXXXXXXX	 	cmdId: 	000C
timestamp: 	2018-11-14T08:21:50+00:00	 	type: 	BLE-SendingMsg	 	nukiId: 	XXXXXXXX	 	cmdId: 	0001
timestamp: 	2018-11-14T08:21:50+00:00	 	type: 	BLE-Connect	 	handles: 	ARRAY(0x6393b60)
timestamp: 	2018-11-14T08:21:50+00:00	 	type: 	BLE-Connected	 	nukiId: 	XXXXXXXX
timestamp: 	2018-11-14T08:21:49+00:00	 	type: 	BLE-Connect	 	macAddr: 	XXXXXXXXXXXX
timestamp: 	2018-11-14T08:21:49+00:00	 	type: 	BLE-Connect	 	nukiId: 	XXXXXXXX
timestamp: 	2018-11-14T08:21:49+00:00	 	type: 	BLE-Retry	 	nukiId: 	XXXXXXXX	 	count: 	1
timestamp: 	2018-11-14T08:21:49+00:00	 	type: 	BLE-Disconnected	 	nukiId: 	XXXXXXXX
timestamp: 	2018-11-14T08:21:49+00:00	 	type: 	BLE-Connected	 	nukiId: 	XXXXXXXX
timestamp: 	2018-11-14T08:21:48+00:00	 	type: 	BLE-Connect	 	macAddr: 	XXXXXXXXXXXX
timestamp: 	2018-11-14T08:21:48+00:00	 	type: 	BLE-Connect	 	nukiId: 	XXXXXXXX
timestamp: 	2018-11-14T08:21:48+00:00	 	type: 	BLE-StatusUpdate	 	nukiId: 	XXXXXXXX
timestamp: 	2018-11-14T08:21:39+00:00	 	type: 	WLAN-SocketDisconnected	 	connection: 	0
timestamp: 	2018-11-14T08:21:39+00:00	 	type: 	HTTP-Info
timestamp: 	2018-11-14T08:21:39+00:00	 	type: 	WLAN-SocketConnected	 	connection: 	0
timestamp: 	2018-11-14T08:21:14+00:00	 	type: 	WLAN-SocketDisconnected	 	connection: 	0
timestamp: 	2018-11-14T08:21:14+00:00	 	type: 	HTTP-Info
timestamp: 	2018-11-14T08:21:14+00:00	 	type: 	WLAN-SocketConnected	 	connection: 	0
timestamp: 	2018-11-14T08:20:47+00:00	 	type: 	WLAN-SocketDisconnected	 	connection: 	0
timestamp: 	2018-11-14T08:20:46+00:00	 	type: 	HTTP-Info
timestamp: 	2018-11-14T08:20:46+00:00	 	type: 	WLAN-SocketConnected	 	connection: 	0
timestamp: 	2018-11-14T08:20:25+00:00	 	type: 	WLAN-SocketDisconnected	 	connection: 	0
timestamp: 	2018-11-14T08:20:25+00:00	 	type: 	HTTP-Info
timestamp: 	2018-11-14T08:20:25+00:00	 	type: 	WLAN-SocketConnected	 	connection: 	0
timestamp: 	2018-11-14T08:20:04+00:00	 	type: 	WLAN-SocketDisconnected	 	connection: 	0
timestamp: 	2018-11-14T08:20:04+00:00	 	type: 	HTTP-Info
timestamp: 	2018-11-14T08:20:04+00:00	 	type: 	WLAN-SocketConnected	 	connection: 	0
timestamp: 	2018-11-14T08:19:42+00:00	 	type: 	WLAN-SocketDisconnected	 	connection: 	0
timestamp: 	2018-11-14T08:19:42+00:00	 	type: 	HTTP-Info
timestamp: 	2018-11-14T08:19:42+00:00	 	type: 	WLAN-SocketConnected	 	connection: 	0
timestamp: 	2018-11-14T08:19:23+00:00	 	type: 	WLAN-SocketDisconnected	 	connection: 	0
timestamp: 	2018-11-14T08:19:16+00:00	 	type: 	HTTP-Info
The Smartlock is removed from the bridge and added.
CallBack deleted from the bridge and created again.
I found HTTP-POST Events in the Log
timestamp: 2018-11-14T09:44:10+00:00 type: HTTP-Info
timestamp: 2018-11-14T09:44:10+00:00 type: WLAN-SocketConnected connection: 0
timestamp: 2018-11-14T09:44:08+00:00 type: HTTP-PostFailed urlId: 0
timestamp: 2018-11-14T09:44:07+00:00 type: WLAN-SocketDisconnected connection: 3
timestamp: 2018-11-14T09:44:05+00:00 type: WLAN-SocketDisconnected connection: 0
timestamp: 2018-11-14T09:44:05+00:00 type: WLAN-SocketConnected connection: 0
timestamp: 2018-11-14T09:43:55+00:00 type: WLAN-SocketDisconnected connection: 0
timestamp: 2018-11-14T09:43:55+00:00 type: WLAN-SocketConnected connection: 0
timestamp: 2018-11-14T09:43:55+00:00 type: BLE-Disconnected nukiId: XXXXXXXX
timestamp: 2018-11-14T09:43:55+00:00 type: BLE-Disconnect nukiId: XXXXXXXX
timestamp: 2018-11-14T09:43:54+00:00 type: WLAN-SocketDisconnected connection: 0
timestamp: 2018-11-14T09:43:54+00:00 type: WLAN-SocketConnected connection: 0
timestamp: 2018-11-14T09:43:52+00:00 type: HTTP-Post urlId: 0 nukiId: XXXXXXXX
timestamp: 2018-11-14T09:43:52+00:00 type: BLE-ReceivingMsg nukiId: XXXXXXXX cmdId: 000E
timestamp: 2018-11-14T09:43:52+00:00 type: SSE-KeyturnerResponse nukiId: XXXXXXXX bytes: 188
timestamp: 2018-11-14T09:43:52+00:00 type: BLE-ReceivingSSE bytes: 55 auth: XXXXXXXX
timestamp: 2018-11-14T09:43:52+00:00 type: SSE-KeyturnerResponse nukiId: XXXXXXXX bytes: 256
timestamp: 2018-11-14T09:43:52+00:00 type: BLE-ReceivingSSE bytes: 107 auth: XXXXXXXX
timestamp: 2018-11-14T09:43:51+00:00 type: SSE-KeyturnerRequest nukiId: XXXXXXXX bytes: 96
timestamp: 2018-11-14T09:43:51+00:00 type: BLE-SendingSSE bytes: 96 auth: XXXXXXXX
timestamp: 2018-11-14T09:43:51+00:00 type: WLAN-SocketConnected connection: 3
timestamp: 2018-11-14T09:43:50+00:00 type: BLE-ReceivingMsg nukiId: XXXXXXXX cmdId: 000E
timestamp: 2018-11-14T09:43:50+00:00 type: SSE-KeyturnerResponse nukiId: XXXXXXXX bytes: 228
timestamp: 2018-11-14T09:43:50+00:00 type: BLE-ReceivingSSE bytes: 86 auth: XXXXXXXX
timestamp: 2018-11-14T09:43:50+00:00 type: SSE-KeyturnerRequest nukiId: XXXXXXXX bytes: 56
timestamp: 2018-11-14T09:43:50+00:00 type: BLE-SendingSSE bytes: 56 auth: XXXXXXXX
timestamp: 2018-11-14T09:43:50+00:00 type: SSE-KeyturnerResponse nukiId: XXXXXXXX bytes: 212
timestamp: 2018-11-14T09:43:50+00:00 type: BLE-ReceivingSSE bytes: 73 auth: XXXXXXXX
timestamp: 2018-11-14T09:43:49+00:00 type: BLE-SendingSSE bytes: 56 auth: XXXXXXXX
timestamp: 2018-11-14T09:43:49+00:00 type: BLE-Connect handles: ARRAY(0x6089750)
timestamp: 2018-11-14T09:43:49+00:00 type: BLE-Connected nukiId: XXXXXXXX
timestamp: 2018-11-14T09:43:49+00:00 type: BLE-Connect macAddr: XXXXXXXXXXXX
timestamp: 2018-11-14T09:43:49+00:00 type: BLE-Connect nukiId: XXXXXXXX
timestamp: 2018-11-14T09:43:49+00:00 type: SSE-KeyturnerRequest nukiId: XXXXXXXX bytes: 56
timestamp: 2018-11-14T09:43:49+00:00 type: SSE-KeyturnerEventResp nukiId: XXXXXXXX
timestamp: 2018-11-14T09:43:49+00:00 type: HTTP-PostStart
timestamp: 2018-11-14T09:43:49+00:00 type: BLE-Disconnected nukiId: XXXXXXXX
timestamp: 2018-11-14T09:43:49+00:00 type: BLE-Disconnect nukiId: XXXXXXXX
timestamp: 2018-11-14T09:43:48+00:00 type: SSE-KeyturnerEventReq nukiId: XXXXXXXX
timestamp: 2018-11-14T09:43:48+00:00 type: BLE-ReceivingMsg nukiId: XXXXXXXX cmdId: 000C
timestamp: 2018-11-14T09:43:48+00:00 type: BLE-SendingMsg nukiId: XXXXXXXX cmdId: 0001
timestamp: 2018-11-14T09:43:48+00:00 type: BLE-Connect handles: ARRAY(0x6122ea0)
timestamp: 2018-11-14T09:43:48+00:00 type: BLE-Connected nukiId: XXXXXXXX
timestamp: 2018-11-14T09:43:48+00:00 type: BLE-Connect macAddr: XXXXXXXXXXXX
timestamp: 2018-11-14T09:43:48+00:00 type: BLE-Connect nukiId: XXXXXXXX
timestamp: 2018-11-14T09:43:48+00:00 type: BLE-StatusUpdate nukiId: XXXXXXXX
HTTP-PostStart shows that the callback has been sent.
HTTP PostFailed urlId: 0
normally means that the URL for the 1. set callback was not reachable.
We could track down the problem and hope to fix it with the next FW-update.
sounds great :slight_smile:
Thank you all for helping. I found my problem. Thanks Nuki, as always faster and more helpful support.
Short explanation. It probably freeze my webhook socket. Sorry for troubble.
Leon
No worries with your thread we found that my problem is indeed a firmware bug :slight_smile:
Have a nice day,
Niklas
I just changed my lock with a 2.0 version to find out this is indeed not working ATM. Do you have an ETA for when this fix will be available?
Sorry, no ETA yet. But I will update it here as soon as possible.
The new Beta-FW for the SL is out since yesterday (v.2.3.4) and fixes the issue in our tests (and also according to @creak :wink: )
Hello. I have FW 2.3.10 on my Nuki Lock and current lock state does not update through webhook. Since I’m having problems with current lock state in HomeKit I tried to use nukiio homebridge plugin (homebridge-nukiio - npm). I set webhook server ip and port and I can see it in callback list (IP is RPi’s one where homebridge in running). But when I make action state in Home app is not changed and I can see in homebridge log that state in actually wrong. I tested all of the below options:
Only first option where HTTP lockState call is made every time seems to work OK. The second one and also the third one are returning wrong current lock state.
I can’t say anything about the function of the homebridge plugin.
Regarding our HTTP API:
  • If you keep pulling the state via /lockState endpoint this will drain the Smart Locks batteries quite fast
  • /list endpoint shows correct lockStatus for me with a very small delay
  • /callback is also working for me with SL with FW 2.3.10
I am the developer of the homebridge plugin. Please post your issue here: https://github.com/benzman81/homebridge-nukiio/issues
