The use of KeyPad2 is useless, I mean 1 out of 10 the opening is instantaneous.
The LEDs keep scrolling for about 30s then they stop and the door does not open.
The log does not show anything, I try again and it opens immediately but sometimes it does it again.
I don’t know if version 1 was better.
On the other hand, Nuki Fob is instantaneous and never fails.
I have the Nuki 3Pro I think it is the keyboard I have tested it on two units this one I can add new prints.
The previous one was faulty and could not add fingerprints it said it had no bluetooth connection.
And with the use of fingerprint is worse fails a lot should put immediately that does not work and let me try again because opening a door with these failures is horrible 3 attempts these 5 min in front without being able to open and use the key.
I have a separate separate keypad and I open it with a door opener I end up using my keypad but I can’t open it if the key is out I will have to connect it to a Fob so it will be instantaneous.
If the Nuki Fob is always instant opening.
It is because the keyPad2 is not working properly but I have had several so it is a failure of the KeyPad2.
Any solution?
I think it is a bluetooth connection issue with the Nuki 3 Pro because the Fob does it correctly.
I show a video and you will see that it does not appear in the history only appears when I open but when the led blinks twice it does not open the door and you do not show it in the history.
Any beta solution?
Why doesn’t it happen with Nuki Fob?
