Keypad 2 Updates
Keypad 2 Beta 2.4.5
(23.10.2025)
- Upgrade to the latest chipset SDK
- Performance improvements and bug fixes
Keypad 2 Beta 2.4.10
(17.03.2026)
- Bluetooth connectivity improvements
Keypad 2 Beta 2.4.5
(23.10.2025)
(17.03.2026)
Good morning Daniel
Could you please advise how a Beta can be installed?
I still hope with a newer Firmware Version and improved Performance (as mentioned) and Bug fixes to improved the Fingerprint detection. Also to solche issues which are described Here Keypad 2.0 invalid fingerprint issue 0xE1
Thanks and Kind regards
Hello Tobias,
Please read thought the guidelines on how to become a Nuki tester and receive the latest Beta in the link Below:
How to become a Nuki Accessory (Fob, Keypad, Door Sensor) tester
Looking at the issue you mentioned, this Beta does not provide any specific improvements regarding Fingerprint sensor.
Please stay tuned for the upcoming improvements in this regard.
Thanks for your support,
Daniel
Initial post has been updated with the release notes of the new Beta 2.4.10.
(17.03.2026)
We highly appreciate your feedback provided from all our Beta testers and are eager to improve our products to achieve the best user experience. Please try out this new version and provide feedback in this channel in order to shape the experience.
Thank you for your continued support ![]()
I do notice that the opening of the lock reacts slower when I use my finger on the scanner.
I have same problem as other users. Super slow connectivity after update to 2.4.11.
Before it was almost instatly.
Now, I must wait 3-4 seconds. Please back old firmware or update with fix ![]()
If you’re using a Smart Lock 5th gen, could someone who is affected please upgrade to the latest Smart Lock beta and let us know if the problem still persists and if something changed with the update or if it remained unchanged?
The problem is with the latest beta version of the ultra.
Yes, still persist, also on beta as on regular (5.7.8).
Thanks for your feedback. We are investigating this system behaviour and will keep you informed here.
If you have a severe impact on your setup, please also contact the Nuki Customer Support via the Nuki App.
Issue is also on the Lock 3 Pro, but keypad was updated to 2.4.11 not being on the Beta program. Not sure what happened here.
Same for my KP2 NFC. Was already on 2.4.11 (not being beta at all as fresh out the box, doing initial firmware update)
Beta firmware has resolved the issue for me, as far as I can test anyways!
