Is the BTicino 344652 Classe 100V16B compatible?
Hello everyone,
I want to connect the Nuki Opener White to my BTicino 344652 Classe 100V16B but I don’t know if it’s comptabile or not, it doesn’t even appear on the list in Nuki Website …
Here is a picture of my BTicino 344652
Somebody can help me please ? really need this system to unlock the residence door for my Airbnb
Is this configuration works for the BTicino 344652 ? :
It’s a configuration that I found in this thread :
I can’t quite say for sure, but it looks like this bTicino unit uses the 2-wire SCS bus system. If so, compatibility with the Nuki Opener will be hit or miss depending on the quality of the wiring in your house. It might work or it might not, the only way to find out is to try it out.
Unfortunately, the Nuki Opener does not fully decode the bticino SCS protocol, it only captures/replays packets, which might work in some cases, but did not work reliably at all in my case.
I have written quite a lot about the underlying issue and the fix that I ended up using:
Hope this helps, and I also hope that some day Nuki developers will actually implement proper bticino support…
