Hi @Stephan
{"timestamp": "2020-10-10T09:23:21+00:00", "type": "HTTP-Log"},
{"timestamp": "2020-10-10T09:23:19+00:00", "nukiId": "XYZ", "type": "BLE-Disconnected", "pairIndex": 0, "bleHandle": "0001"},
{"timestamp": "2020-10-10T09:23:19+00:00", "nukiId": "XYZ", "type": "BLE-Disconnect", "pairIndex": 0, "bleHandle": "0001"},
{"timestamp": "2020-10-10T09:23:19+00:00", "nukiId": "XYZ", "type": "BLE-ConnectionTimeout"},
{"timestamp": "2020-10-10T09:23:14+00:00", "nukiId": "XYZ", "type": "BLE-CommandComplete", "pairIndex": 0},
{"timestamp": "2020-10-10T09:23:14+00:00", "nukiId": "XYZ", "type": "SSE-KeyturnerResponse", "pairIndex": 0, "bytes": 245},
{"timestamp": "2020-10-10T09:23:14+00:00", "nukiId": "XYZ", "type": "BLE-SendingSSE", "pairIndex": 0, "bytes": 56},
{"timestamp": "2020-10-10T09:23:14+00:00", "nukiId": "XYZ", "type": "BLE-TurnOnNotific", "pairIndex": 0},
{"timestamp": "2020-10-10T09:23:14+00:00", "nukiId": "XYZ", "type": "BLE-Connected", "pairIndex": 0, "bleHandle": "0001"},
{"timestamp": "2020-10-10T09:23:14+00:00", "type": "BLE-Connect", "macAddr": "XYZ"},
{"timestamp": "2020-10-10T09:23:14+00:00", "nukiId": "XYZ", "type": "BLE-Connect", "pairIndex": 0},
{"timestamp": "2020-10-10T09:23:14+00:00", "nukiId": "XYZ", "type": "SSE-KeyturnerRequest", "pairIndex": 0, "bytes": 56},
{"timestamp": "2020-10-10T09:23:11+00:00", "type": "HTTP-List"},
{"timestamp": "2020-10-10T09:22:52+00:00", "nukiId": "XYZ", "type": "BLE-Disconnected", "pairIndex": 0, "bleHandle": "0001"},
{"timestamp": "2020-10-10T09:22:52+00:00", "nukiId": "XYZ", "type": "BLE-Disconnect", "pairIndex": 0, "bleHandle": "0001"},
{"timestamp": "2020-10-10T09:22:52+00:00", "nukiId": "XYZ", "type": "BLE-ConnectionTimeout"},
{"timestamp": "2020-10-10T09:22:47+00:00", "nukiId": "XYZ", "type": "BLE-CommandComplete", "pairIndex": 0},
{"timestamp": "2020-10-10T09:22:47+00:00", "nukiId": "XYZ", "type": "SSE-KeyturnerResponse", "pairIndex": 0, "bytes": 237},
{"timestamp": "2020-10-10T09:22:47+00:00", "nukiId": "XYZ", "type": "BLE-AlreadyConnected", "pairIndex": 0},
{"timestamp": "2020-10-10T09:22:47+00:00", "nukiId": "XYZ", "type": "SSE-KeyturnerRequest", "pairIndex": 0, "bytes": 56},
{"timestamp": "2020-10-10T09:22:47+00:00", "type": "SSE-KeyturnerEventResp"},
{"timestamp": "2020-10-10T09:22:47+00:00", "type": "HTTP-Post", "nukiId": "XYZ"},
{"timestamp": "2020-10-10T09:22:47+00:00", "nukiId": "XYZ", "type": "SSE-KeyturnerEventReq"},
{"timestamp": "2020-10-10T09:22:47+00:00", "nukiId": "XYZ", "type": "BLE-ReadStates", "pairIndex": 0},
{"timestamp": "2020-10-10T09:22:47+00:00", "nukiId": "XYZ", "type": "BLE-TurnOnNotific", "pairIndex": 0},
{"timestamp": "2020-10-10T09:22:47+00:00", "nukiId": "XYZ", "type": "BLE-Connected", "pairIndex": 0, "bleHandle": "0001"},
{"timestamp": "2020-10-10T09:22:47+00:00", "type": "BLE-Connect", "macAddr": "XYZ"},
{"timestamp": "2020-10-10T09:22:47+00:00", "nukiId": "XYZ", "type": "BLE-Connect", "pairIndex": 0},
{"timestamp": "2020-10-10T09:22:47+00:00", "nukiId": "XYZ", "type": "BLE-StateChanged", "pairIndex": 0},
{"timestamp": "2020-10-10T09:22:41+00:00", "type": "HTTP-List"},
{"timestamp": "2020-10-10T09:22:11+00:00", "type": "HTTP-List"},
{"timestamp": "2020-10-10T09:21:41+00:00", "type": "HTTP-List"},
{"timestamp": "2020-10-10T09:21:10+00:00", "type": "HTTP-List"},
{"timestamp": "2020-10-10T09:20:41+00:00", "type": "HTTP-Log"},
{"timestamp": "2020-10-10T09:20:40+00:00", "type": "HTTP-List"},
{"timestamp": "2020-10-10T09:20:10+00:00", "type": "HTTP-List"},
{"timestamp": "2020-10-10T09:19:40+00:00", "type": "HTTP-List"},
{"timestamp": "2020-10-10T09:19:10+00:00", "type": "HTTP-List"},
{"timestamp": "2020-10-10T09:18:40+00:00", "type": "HTTP-List"},
{"timestamp": "2020-10-10T09:18:10+00:00", "type": "HTTP-List"},
{"timestamp": "2020-10-10T09:17:40+00:00", "type": "HTTP-List"},
{"timestamp": "2020-10-10T09:17:13+00:00", "type": "HTTP-Log"},
{"timestamp": "2020-10-10T09:17:09+00:00", "type": "HTTP-List"},
{"timestamp": "2020-10-10T09:16:47+00:00", "nukiId": "XYZ", "type": "BLE-Disconnected", "pairIndex": 0, "bleHandle": "0001"},
{"timestamp": "2020-10-10T09:16:47+00:00", "nukiId": "XYZ", "type": "BLE-Disconnect", "pairIndex": 0, "bleHandle": "0001"},
{"timestamp": "2020-10-10T09:16:47+00:00", "nukiId": "XYZ", "type": "BLE-ConnectionTimeout"},
{"timestamp": "2020-10-10T09:16:42+00:00", "type": "HTTP-Post", "nukiId": "XYZ"},
{"timestamp": "2020-10-10T09:16:42+00:00", "nukiId": "XYZ", "type": "BLE-ReadStates", "pairIndex": 0},
{"timestamp": "2020-10-10T09:16:42+00:00", "nukiId": "XYZ", "type": "BLE-Retry", "pairIndex": 0, "count": 1},
{"timestamp": "2020-10-10T09:16:42+00:00", "nukiId": "XYZ", "type": "BLE-TurnOnNotific", "pairIndex": 0},
{"timestamp": "2020-10-10T09:16:42+00:00", "nukiId": "XYZ", "type": "BLE-Connected", "pairIndex": 0, "bleHandle": "0001"},
{"timestamp": "2020-10-10T09:16:42+00:00", "type": "BLE-Connect", "macAddr": "XYZ"},
{"timestamp": "2020-10-10T09:16:42+00:00", "nukiId": "XYZ", "type": "BLE-Connect", "pairIndex": 0},
{"timestamp": "2020-10-10T09:16:42+00:00", "type": "BLE-EarlyDisconnect", "nukiId": "XYZ"},
{"timestamp": "2020-10-10T09:16:42+00:00", "nukiId": "XYZ", "type": "BLE-StateChanged", "pairIndex": 0}
I ring the door, leads to first HTTP-Post at 9:16:42 that is not working. Then I used ‘curl -d “” http://192.168.178.4/api/webhook/nuki_opener’ against Home Assistant to trigger the Home Assistan service manually and again ring the door with HTTP-Post at 9:22:47 and it is back working…
But I am not sure if this a Nuki or a Home Assistant Problem… Maybe you can point me into the right direction…
