@MatthiasK Hi
I cannot restart the webhook after high failure rate.
I submitted a ticket but unfortunately the first level is not answering (suggesting all kind of non related procedures first then not responding)
Can You help with that?
I simply had 100% failure rate and then the restart webhook does not work now.
Thank You in advance
Best Regards
I got a bit confused as this was posted within a topic under the Bridge API categorie but it seems you have the issue with the Web API webhooks (so something completely different to the topic discussed here)?
If you restart webhooks there we do a retry of a call to the entered webhook URL. If the retry fails webhooks are not reactivated.
EDIT: I split the topic now to avoid confusion.
