I can’t connect my Nuki 2.0 to my Home Assistant smart hub even when I use my Nuki Api Token (that is much longer than 20 character as in the explanation in Home Assistant forum). Someone can help?
Hi Francesco, I have the same issue. Did you manage to get it connected?
You need http api token not web api
if you haven’t solved it yet try this:
