@Panda
Dont mind the cables there, i took the Pictures when initially trying top Install via nuki generic Bus procedure. Just wanted top know If the Spot i labled gnd ist really ground and thus should bei connected to black& purple. And If the circle closest to the “Opener Pin” should be connected to the blue cable.
Because thats how i have it at the moment and it doesnt work.
Can Take Pictures of the actual new wiring as soon as home later.
@Panda , the black cable ist soldered tobte gnd Pin marked in the other Pictures, the yellow one should be between Button and chip
Opener part seems to look good to me, so I don’t know why it wouldn’t work. Does ring suppression work?
Hey @Panda and @nnpl - does your solution work now? I also have a SKS 4500_3 and am trying to get it work. Already order cables and connectors but wanna make sure you guys got it working. Thx
Hi Georg,
I have the same issue. Could you please provide me the instructions?
I’m hardware engineer.
Besten Dank!
VG, Samir
I am trying to use this workaround to get a SKS DS2010 to work with the Opener.
Sadly I can’t find the opener pin (at least I think that is my problem).
Has anyone experience with that one and might be able to help me?
I do not net ring suppression, I just want to use the opener to open the door after I ring (when I am in the geofence).
I would be extremely grateful for any support!
Best wishes
Fabian
@Panda, thanks for your effort! Do you have 2 Doors/Cameras on the house? And Opener opens both at the same time?
@Zauberelfe00 did you solve the problem with your 8879.
please help me with mine
