Can't load Lock Firmware 1.7.3
(Kevin Fox) #1
My beta app has offered up Firmware 1.7.3 but when it comes to transferring to the smart lock it sits at 0% I’ve tried taking the batteries out of the Smartlock for 10 seconds but the problem remains. I’m using iOS 12.1.1 beta
How can I fix this?
(Jürgen Pansy) #2
Please switch on Debug Log (Menu > Settings), try it again and send a log via mail to developer@nuki.io.
(Kevin Fox) #3
There is no debug option all I have is:
Manage Smartlock
Manage Users
Activity Log
Display Name
Favourite
Smart options (auto unlock)
Connection Status
Actions
Swipe to Left
Swipe to Right
Delete Smartlock
(Stephan Lendl) #4
You have to open the hamburger menu at the top left!
See:
(Kevin Fox) #5
Got it - hadn’t been in there yet :slight_smile: will send log later
(Kevin Fox) #6
Logfile sent to contact@nuki.io
(jOe) #7
Same problem here. Tried it several times
(Stephan Lendl) #8
Please also send us a log-file as described above!
(jOe) #9
Okay Email ist raus.
(Jorden Chamid) #10
I had the same. It went to 1% uploading to device, back to 0% and then after some time an error popup.
I removed the batteries, still the same problem. Received a message that the batteries were low. Replaced the batteries and then I could update without a problem.
(Jürgen Pansy) #11
The latest beta 2.0.1 has a fix for this upload problem. Have you been on it or did you use an older one?
(jOe) #12
Last Beta fixed the Problem :+1:
(Kevin Fox) #13
Latest V2.0.1 beta fixed it for me, although new firmware kept as long for lock to be calibrated after I had calibrated it. Gave up after 3 calibrations and it seems to work
