Please contact our support via https://nuki.io/en/support-request/ or contact@nuki.io for more detailed information.
Sure thanks I will contact. Nevertheless ITâS a developer related issue.
At beginning I thought of a faulty hardware, but reading this post with so many people with same issue, its most probably a software issue, so it is appropriate to post it here.
I do have a smart home with hundreds of devices (zwave, zigbee, wifi, , so I am not a professional neither a novice. The bridge tries to connect but it fails
Anyone did a small device based on a ESP8266 together with the KeyFOB?
I want to use the bridge with Home Assistant, so to me the Nuki Bridge, or an ESP8266 is the same thing, but the latter I am sure it works
Same here new from box bridge internal fault 04
Grrrrrâ:rage:![]()
If youâr on iOS, please update to version 2023.6.2 and try again. If the problem persists, please contact our customer support within the app (Help â Contact customer support).
