Hello, my bridge is still on 2.3.0 and will not update to newer version.
I tried several times to restart the bridge und forced fwupdate via HTTP API with token_id.
http://10.4.70.100:8080/fwupdate?token=xxxxxx
But the bridge is only flashing the light for just 1 sec than stops blinking and will not updating.
The PING interrupts every vew minutes for a while. The device is not stable.
Antwort von 10.4.70.100: Bytes=32 Zeit=20ms TTL=255
Antwort von 10.4.70.100: Bytes=32 Zeit=6ms TTL=255
Antwort von 10.4.70.100: Bytes=32 Zeit=8ms TTL=255
Antwort von 10.4.70.100: Bytes=32 Zeit=7ms TTL=255
Antwort von 10.4.70.100: Bytes=32 Zeit=5ms TTL=255
Zeitüberschreitung der Anforderung.
Antwort von 10.4.70.103: Zielhost nicht erreichbar.
Antwort von 10.4.70.100: Bytes=32 Zeit=1756ms TTL=255
Antwort von 10.4.70.100: Bytes=32 Zeit=4ms TTL=255
Antwort von 10.4.70.100: Bytes=32 Zeit=106ms TTL=255
How can I fix this issue? Thank you in advance.
Regards
Thomas
---------- edit -----------------
Ok, I fixed this issue by doing a factory-reset. After this, the bridge has updated to 2.4.26
