I am considering buying 230V - 4x AA Adapter voor batterijartikelen . I do not like the idea that the batteries are empty when a Airbnb guest arrives at my house. Can some Nuki expert tell me if this could be a solution? I think I will need to drill a hole somewhere in the Smart Lock. Is this an option that Nuki could support?
Hello.
The device has to have 3 Amps output.
Your link does not have that information.
You have to ask them before buying.
Regards.
I have contacted the shops that sells that product and they are going to contact the producer to ask about the Amps and also to ask if a longer cable is possible.
But if so… can I safely drill a hole in the Nuki? If yes where exactly? Are there technical drawings available?
If it is 3 Amps you can buy it and follow this link:
Please report back to us whether you managed to connect the device.
Regards.
