WordPress plugin creation
I’m Sébastien, a French WordPress developer owner of a Smartlock Pro 3.0.
I started to create a WordPress plugin which automatically lock the smartlock between 2 predefined hours.
This was developed before discovering the native Nuki “night” feature but the advantage of a WordPress plugin is you can manage your own cron schedule.
If you have some other feature, you would like to have on a WordPress plugin, I’m opened to check if it’s possible for me to develop it.
GitHub - sebastienserre/connect-your-nuki-smartlock (soon on wordpress.org)
Regards
I’m very happy to announce you a first release of my WordPress plugin is available on the official repository at Connect your Nuki Smartlock! – WordPress plugin | WordPress.org
This is a more first package needed to make the WooCommerce Bookings integration available at Streamline Bookings with WooCommerce & Nuki
If you have any question or needs about Nuki on WordPress, do not hesitate, I will evaluate each demand.
Hope this will help you.
Regards
Hi Sebastian,
First of all, thats a perfect idea :). Do you think we could have a trial of the Nuki Smartlock & Keypad pluging for Woo that we could test, before buying (like a trial or smth?)
2nd Does that handle the issue of the same code for multiple devices? (e.g I have a customer who needs to access both main door and apartment door bot with smartlock+keypad), so it would be perfect if the same pin code is issued for both devices
Thats’ clear I need to work on the website :-), but that’s less fun than working on the plugin ;-). I have added a 30 days free trial.
In any case, let me know if any issue from this forum or through the contact form on the website.
At the moment, I have only allow to have 1 smartlock+keypad per bookings, but I think kit should be to add several and send the same code. :thinking:
My main difficulties is, I only have 1 at home… and I won’t be able to test my developments :frowning:
Regards
I’ve received a second pack (Nuki 3.0 Pro + Keypad).
My development seems to work. You can already display Nuki Smartlock state on a WordPress Dashboard widgets thanks to Connect your Nuki Smartlock! – WordPress plugin | WordPress.org.
My add on for WooCommerce Bookings is on progress to manage several smartlock per rental (1 pincode by smartlock or the same pincode for several smartlock) Streamline Bookings with WooCommerce & Nuki
Hi, such a plugin is exactly what we were looking for. However, we use YiTH Booking and Appointment with Woocommerce. Will your plugin work with it?
My plugin is at the moment only available with WooCommerce Booking but we can think about a version for Yith Booking.
Could you please contact me through Contact us - Nuki smartlock for WordPress and we’ll see together, what’s possible.
Regards
Hi Sebastien !
What is the status of this plugin ?
Is it still available or some work on it is done ?
I’m looking for a plugin for MotoPress Hotel Booking to deliver access with new Nuki 4 smart lock.
I own one smart lock for each property. And I would like to deliver 1 to 3 “keys” to the customers that rent the fiat in order they can have keys on several or their phones.
This plugin has developed based n the Nuki 3 Pro I have at home.
I do not have any Nuki 4 to test if the plugin is working.
I do not know MotoPress and there’s no compatibility with this plugin.
More information at https://nuki-smartlock-for-wp.com/
Regards
Thanks Sébastien for your kind reply. I’m going to look at your code to see if I can adapt it. I’ll post there my progress if I succeed. I start by creating the authentication token for the account and the 2 smartlock 4 IDs.
Hi, I am interested in the Woocommerce Booking Integration. I have seen only couple of posts about this private project. Does this plugin work well? Does code gets invalid/cancels in case of booking cancellation?
Does it already work with 4 Pro?
Best regards,
Mej
I am also looking for a solution for motopress and nuki… have you found a solution? Is the plugin still being developed? does it work with the Nuki Pro 4?
The plugin is still developed but I’m alone and do not have any other request for MotoPress.
I also do not hav a Pro 4 version to test if it works.
If they do not change the API, I think it should work.
Regards
Hi !
I asked again a few days ago to motopress team if they can do this plugin as they have made more complex plugins like airbnb but not enough of their customers asked for it.
Please go to motopress dev forum and ask for it. If we are several to ask they can do it. I send them a small requirement list and Sebastien plugin as an example. When we know Wordpress plugins and Motopress plugins structure as them it is a very short dev 1 day max and I was even ready to pay for it.
They do not plan to do it because they have not enough demand for it. So I suspendend my 299€yeraly subscripton. I will pay it again only when they will have done the plugin to get the update.
And if they don’t decide to do it I will i do it myself this spring
